Go to Post So why are we trying to go to Mars? It's because it's bigger, better, and bolder. Doing what nearly no other team can do, and defying all those who say it can't be done. That reward is a lot more than 9 points. - Mike [more]
Unread 30-01-2006, 16:12
Jimmy Holmes Jimmy Holmes is offline
It's not all about the robots
FRC #0027 (Team Rush)
Rookie Year: 1997
Jimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of light
Re: pic: Team Rush 27 - unofficial teaser
We have always battled with how much rotation is to much. We have gone past 360 degrees in the past and had software stops on it. We would have to have a lot of extra slack in the system as it would shorten with the rotation. We also found it would get confusing at times where you were in the rotation. We had a button that would re-zero it if we got lost. Lets just say i wish the wires would stretch more at times.
We have tried to go with less rotation in the last few years, nothing more than 270 or so. If you are running balls through the center of the turret you will then have to run the wire around the outside which could limit you even more.
Of course you could try slip-rings. We have found them to be cost and time prohibitive but they may work for your application
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 830 Rat Pack Teaser Jeff Waegelin Extra Discussion 24 12-02-2005 23:46
