Go to Post After all, bitterness takes all the fun out of wiring. - Venkatesh [more]
Unread 30-01-2006, 17:27
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Re: pic: Bare minimum
Originally Posted by Greg Marra
A bit of advice:
The radio doesn't really need to be mounted up high like you have it. The radios are very powerful, and mounting it with the rest of your electronics will decrease the amount of wire you need to run and make one less element you need to worry about breaking.
It is generally a good idea to keep the radio antenna vertically oriented.
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
