Go to Post A programmer's job is to write documentation that happens to compile.... :) - buddy.smith [more]
Unread 30-01-2006, 19:39
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Acceleration Curve
We used an acceleration curve to overcome the sensitivity of the low range of the joystick. The code looks exactly like this:
Code:
tempRight = pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
tempLeft = pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
  if(p1_y >= 127){
    tempRight = (tempRight - 127)(tempRight - 127)/127 + 127;
    tempLeft = (tempLeft - 127)(tempLeft - 127)/127 + 127;
  if(p1_y < 127){
    tempRight = (tempRight - 127)(tempRight - 127)/-127 + 127;
    tempLeft = (tempLeft - 127)(tempLeft - 127)/-127 + 127;
  pwm13 = pwm14 = tempRight;
  pwm15 = pwm16 = tempLeft;
When building, the compiler gives error 1202: Call of non-function, on the 4 lines inside the if statements.
I'm completely stumped, any help would be greatly appreciated.
Unread 30-01-2006, 19:44
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
Re: Acceleration Curve
I'm not entirely sure what the error is in your code i will take a look at it again but if u want here is the method i used for doind the same thing u are doing:
try adding brackets for order of operations:
tempRight = (((tempRight - 127) * (tempRight - 127))/127) + 127;
Originally Posted by code
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "cuog_cam.h"
#include "cuog_util.h"
#include "math.h"
void Exp_Joy_Mapping()
char raw = 0;
switch(MAP_NUMBER)
//maps joystick and PWM #8
case 8:
raw = (MAP_JOYSTICK08 - 128) / 11.3;
if(MAP_JOYSTICK08 < 127)
MAP_PWM08 = (raw * raw) - 128;
else
MAP_PWM08 = (raw * raw) + 128;
//maps joystick and PWM #7
case 7:
raw = (MAP_JOYSTICK07 - 128) / 11.3;
if(MAP_JOYSTICK07 < 127)
MAP_PWM07 = (raw * raw) - 128;
else
MAP_PWM07 = (raw * raw) + 128;
//maps joystick and PWM #6
case 6:
raw = (MAP_JOYSTICK06 - 128) / 11.3;
if(MAP_JOYSTICK06 < 127)
MAP_PWM06 = (raw * raw) - 128;
else
MAP_PWM06 = (raw * raw) + 128;
//maps joystick and PWM #5
case 5:
raw = (MAP_JOYSTICK05 - 128) / 11.3;
if(MAP_JOYSTICK05 < 127)
MAP_PWM05 = (raw * raw) - 128;
else
MAP_PWM05 = (raw * raw) + 128;
//maps joystick and PWM #4
case 4:
raw = (MAP_JOYSTICK04 - 128) / 11.3;
if(MAP_JOYSTICK04 < 127)
MAP_PWM04 = (raw * raw) - 128;
else
MAP_PWM04 = (raw * raw) + 128;
//maps joystick and PWM #3
case 3:
raw = (MAP_JOYSTICK03 - 128) / 11.3;
if(MAP_JOYSTICK03 < 127)
MAP_PWM03 = (raw * raw) - 128;
else
MAP_PWM03 = (raw * raw) + 128;
//maps joystick and PWM #2
case 2:
raw = (MAP_JOYSTICK02 - 128) / 11.3;
if(MAP_JOYSTICK02 < 127)
MAP_PWM02 = (raw * raw) - 128;
else
MAP_PWM02 = (raw * raw) + 128;
//maps joystick and PWM #1
case 1:
raw = (MAP_JOYSTICK01 - 128) / 11.3;
if(MAP_JOYSTICK01 < 127)
MAP_PWM01 = (raw * raw) - 128;
else
MAP_PWM01 = (raw * raw) + 128;
break;
KK4KQO
http://voltair.us
Too many projects, too little time.
Unread 30-01-2006, 19:46
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
You need an asterisk (*) to multiply.
Unread 30-01-2006, 19:51
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Thats the one!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 30-01-2006, 19:52
'Doh! Man, 3 years programming C and I still make these stupid mistakes. Yesterday I forgot to end a quotation on a string and the compiler decided to give a syntax error on a comment 20 lines down
Thanks alot for the help guys, it's always nice to have the outside party take a look at your code because one of two things can happen:
1. They write it better.
2. They find your stupid mistake.
Unread 01-02-2006, 16:27
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
3. You can help them find their stupid mistakes. Stupid if statements ;-)
Matt Krass
(SolidWorks) Create Sketch Points Around Curve Yan Wang Inventor 6 04-08-2005 21:20
Acceleration Sensor Connected, but values are odd.... Leav Electrical 7 04-02-2005 15:28
van door torque curve DLyons Motors 1 13-01-2003 21:54
Drill motor torque curve thedillybar Motors 1 10-03-2002 05:19
The Learning Curve Was Steep! Mike McIntyre OCCRA 0 12-11-2001 00:23
