Go to Post Dee and I pooling our brain cells almost make a full deck... - RoboMom [more]
Unread 30-01-2006, 20:39
BlackRoboDragon's Avatar
BlackRoboDragon BlackRoboDragon is offline
AKA: Joshua Wanzer (Wanzer)
FRC #0829 (Digital Goats)
BlackRoboDragon is a name known to allBlackRoboDragon is a name known to allBlackRoboDragon is a name known to allBlackRoboDragon is a name known to allBlackRoboDragon is a name known to allBlackRoboDragon is a name known to all
Send a message via AIM to BlackRoboDragon Send a message via MSN to BlackRoboDragon Send a message via Yahoo to BlackRoboDragon
Re: pic: Bare minimum
It looks pretty good, a little more than we have at the moment, but we're moving along. I'm not sure if the wiring is supposed to be all over the place though, been told it makes it a little more difficult when fixing minor problems and the like. Plus you have to untangle some it looks like, just to figure out which goes where. The radio, I'm not all that sure, but, I don't really think it has to be vertical, if I remember right, it will send/receive signals from all angles, or however you want to put it, in more technical terms if you wish, I'm only a second year, so I don't know all the terms you people use.
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
