Go to Post We build because we can. - Danaca [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-29-2006, 01:21 PM
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
FRC #1675 (Ultimate Protection Squad)
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Exclamation AndyMark and IFI Compatibility
I noticed something yesterday that may have the potential to be a huge problem. I took our new AndyMark omniwheel and put it on a shaft next to a new IFI traction wheel (both 6") - its not by much, but they aren't quite the same size. I went over to my other team and looked at the AndyMark trick wheel and IFI wheel (both 8") and found the same thing.
Minor differences are not much of an issue, but when set on the ground, the IFI wheel made contact and the AndyMark wheels did not. In a setup like ours (2 traction in rear, two omni/trick in front), all wheels will be in contact, but the robot will have a forward lean. I have not taken the time yet to see how much this throws the top of the robot forward (nothing too significant, I hope), but for teams that are pushing the envelope, this could lead to problems.
Again, this is just based on both wheels on the same shaft - our chassis is not quite complete (...a bit behind we are...) so I don't know how well the four wheels sit on the ground (especially the carpet).
I'm wondering if the AndyMark traction wheels, when used with the trick/omni wheels, produce the same result, or if this is a result of two different manufacturers?
Bottom line - I hope that I am getting worked up over nothing. If there is a legitimate issue here, I hope that teams using a similar setup will see this thread and take this into account before going to the inspection sizing box and finding out that they need trim down their front edge a bit.
Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2016 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 01-29-2006, 01:29 PM
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
Re: AndyMark and IFI Compatibility
well the easiest thing you can do to quick fix this problem is to offset the larger wheel by 1/8" if thats what the diffrence is, but like you said if its nothing to major you shouldnt have anything to worry about
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 01-29-2006, 09:19 PM
Yes, that is an easy solution if you catch it now. Its not so easy once you have a completed robot and have to make that change in the pits on Thursday. A team will have to drill a new hole accurately on both sides of the chassis, possibly recut chain, or even relocate gearboxes. As you can see, a simple fix can quickly become a massive undertaking, depending on the complexity of your robot.
If it were the other way around (IFI wheels are the smaller wheel), an extra layer of something (double tread might be TOO much) would do the trick, but the omniwheels being the smaller one makes it a trickier issue.
Kev
Unread 01-29-2006, 09:42 PM
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
In the case of the 6" wheels, you could always see about switching to the AM traction wheels. I am confident that Andy could tell us if there is any noticeable difference between their traction wheels and omni wheels. I have no big ideas about how to solve the 8" problem.
JT
229
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 01-29-2006, 11:18 PM
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
I also noticed a similar thing, however it was with AM traction wheels... they appear to have been 6" before the tread was applied... but they are now bigger than the AM omni wheels.
The leaning robot issue I'm not too concerned about because it is a small amount comparatively. The main issue i can think of is one end (omni wheels) will be dragged along by the traction wheels as they move, IE they don't travel the same distance in one revolution, if the wheels are linked together as ours are with chain to one transmission then either the smaller wheel will be dragged along, or the bigger wheel will have to spin a bit.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 01-29-2006, 11:51 PM
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Are they the same size when you put weight on the traction wheels?
I'd almost guarentee that the difference is a discrepancy between the tread being fully compressed, and the wheel sitting on the ridges of the wedgetop, causing the omniwheels to not contact the ground. Either that, or the OD of the wheel without tread is 6" and the tread adds 1/8-1/4" or so.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-30-2006, 09:36 AM
The "problem" could very well go away once the robot is up to full weight. Like I said, these were just on the shaft. I really don't think it's going to be an issue in the long run, though. I hadn't thought about the wheels dragging, but ours are not tied together, so that shouldn't be an issue for us. Between the squishiness of the tread/omniwhees and the carpet, I don't expect to see a lean on the field...just in the sizing box - where it matters.
Kev
Unread 01-30-2006, 10:06 AM
Noah Melamed's Avatar
Noah Melamed Noah Melamed is offline
FRC #0637 (Mr. T)
FTC #0030 (Mr. T)
Noah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura aboutNoah Melamed has a spectacular aura about
Send a message via AIM to Noah Melamed
I don't have expierence with these specfic wheels but over the summer I learned through communication with Skyway that few if any of their wheels are actually the dimension they are described as, ie an 8" wheel could actually be 7 3/4. This is definatly something to take into account when using varying wheels on a robot.
Unread 01-30-2006, 02:36 PM
I ran through a quick and easy CAD model and even your robot is 37.5" x 59.5" with a 30" wheel base, you should be okay. Therefore, HOPEFULLY no one will have a problem here, unless you are relying on perfectly level surfaces.
Kev
Unread 01-31-2006, 08:14 AM
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Kev
This is good news.
We would've liked to make our Omni wheels and Traction wheels the same exact diameter. The Omni-wheels are right at 6" and 8" while the Traction wheels are about 1/4" larger than their nominal diameter. The Traction wheels are purchased wheels that have been altered to receive a tread and driving hub. We cut a wide groove for the tread, but did not want to cut into the diameter of the wheel any more than we did, to save the strength of the wheel.
Andy B.
Unread 01-31-2006, 10:04 AM
Stu Bloom's Avatar
FRC #1018 (RoboDevils)
This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments.
Our 10" X 3" Skyway pneumatic wheels (used this year and the previous two years - we LOVE 'em) actually measure approximately 10.25" diameter. We are also using 10" omni wheels, and our axle/frame mounting heights are different by the corresponding 1/8". Also since we are driving both from the same transmission, the sprockets are different by 1 tooth to give us similar "wheel surface" speeds.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
My activity for 2012:
  • Midwest Head Ref - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
new from IFI Lil' Lavery General Forum 60 12-10-2005 04:35 PM
