Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 31-01-2006, 11:31
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: White Paper Discuss: .NET (2.0) Composite Dashboard Viewer
This is in response to a few private messages and emails I've received. I made the source available, but the whole point of this application is that you don't need to modify the source code to add custom views. You really don't have to know anything about the dashboard data at all. You only need to follow the instructions in the previous post to create a new user control and add UI elements to display the data. There are a few custom dashboardy (thats a technical term) widgets included, including a sliding bar, LED, CMU camera FOV, and last year's field.
The dashboard views are just user controls that inherit from a base class in the FRC.Dashboard.Typelib assembly. The base class inherits from UserControl, but adds methods that are used as callbacks to notify your control when new dashboard packets are available. The dashboard application loads the controls at runtime and lays them out on tabs in the UI. When a new packet is received it calls the appropriate callback on control loaded in the active tab. When a packet of type data frame1 is received and parsed it will call ShowDataFrame1() on the active view control. Its pretty simple when you dig into the code, but the architecture allows you to extend the functionality without modifying the original source code.
[EDIT]
I forgot to mention that you can use any CLR 2.0 compatible language (C#, VB.NET, or Managed C++) to build custom dashboard views. The step are the same, but the syntax depends on the language. VB.NET 2005 Express Edition is available here: http://msdn.microsoft.com/vstudio/ex...b/default.aspx. I haven't used it and I'm not familiar with the syntax differences.
[/EDIT]
White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team Jessica Boucher Extra Discussion 1 20-11-2005 20:01
White Paper Discuss: .NET Composite Dashboard Viewer seanwitte Extra Discussion 8 06-04-2005 00:15
White Paper Discuss: 2004 Visual Basic 6 Dashboard Control CD47-Bot Extra Discussion 2 01-02-2005 01:56
White Paper Discuss: 2004 .NET dashboard control dll CD47-Bot Extra Discussion 7 13-01-2005 17:32
White Paper Discuss: Team 810's 2004 Dashboard Backend CD47-Bot Extra Discussion 1 07-03-2004 10:32
