Re: pic: Team Rush 27 - Up and out!
What's a good source for long timing belts, like the ones pictured above?
whoa, I like the camera angle
Hmm, this looks close to the hieght limit as it is. Am i right to assume you shooter won't be directly on top of this?
Those particular belts are L-series single-sided belts from McMaster, but Stock Drive carries the similar stuff for cheap. Quote:
That leaves 16.875" for something either above or below the ball tube......and just because it is pictured in a vertical setting doesn't mean it has to stay in a vertical setting. |
wow ...! looks cool, how do you channel the balls into the skinny tube?
