Go to Post quite simply, not putting our best foot forward leaves us open to shooting ourselves in the foot. - Jessica Boucher [more]
Unread 31-01-2006, 23:27
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: pic: Team Rush 27 - Up and out!
Hmm, this looks close to the hieght limit as it is. Am i right to assume you shooter won't be directly on top of this?
Unread 01-02-2006, 08:21
ajlapp ajlapp is offline
AKA: Anthony Lapp
What's a good source for long timing belts, like the ones pictured above?
www.sdp/si.com
Those particular belts are L-series single-sided belts from McMaster, but Stock Drive carries the similar stuff for cheap.
You are not right to assume this. The belts pictured have an ideal center distance of 43.125"
That leaves 16.875" for something either above or below the ball tube......and just because it is pictured in a vertical setting doesn't mean it has to stay in a vertical setting.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 01-02-2006, 10:14
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
wow ...! looks cool, how do you channel the balls into the skinny tube?
Team 701
