Go to Post please....Mr. Needel is my father :rolleyes: - Greg Needel [more]
Unread 01-02-2006, 00:21
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pic: Team 1388: Getting there ..
Originally Posted by Alekat
I would never even think about trying to weld and get the wheel shaft holes to line up.
Hehehe.
Ok, so maybe we cheated a little bit. Maybe these will clear it up ..
Basically, we took a solid aluminum rod, turned the outsides down enough to fit into the holes we drilled into the frame, and drilled out the center of the rod (all this was done on a mill and a lathe). Stick the 2 frame rails together, and it lines up perfectly. Clamp and weld. Once we welded the 4 2x1 braces in (you can see them in the top picture), we cut out tubes. Milled it down so 1/16" is outside the frame (so we didn't cut the entire weld off). Our wheels are going to be driven off the hub on the wheel, so the shaft doesn't have to spin. It took alot of machining, and work to get it right, but the final result is something that is dead on straight. Nothing worse than a robot that doesnt drive straight.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
East Coast Drivers Union Corey Balint FIRST-related Organizations 153 10-04-2006 15:50
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
pic: Team 1388 Gearbox Mike Hendricks Robot Showcase 5 07-02-2005 17:26
pic: Team 1388 Teaser #2 jgannon Extra Discussion 7 03-02-2005 02:05
