Go to Post Is the bottom slot just to make the whole thing look like a smiley face, or is it functional? - Chris is me [more]
Unread 31-01-2006, 23:27
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Programming Victor 884 control
i have been batting this around for a few days but we cant seem to get our program to make the victors to move the motor.
we have everything plugged up and the cables in the right way.
we use:
Code:
pwm03 = (unsigned char)127;
and the motor doesnt move which is good.
light on the victor stays solid orange which is also good.
we use:
Code:
pwm03 = (unsigned char)140;
and the motor turns one way at a fair speed;
light turns off . . . good
we use:
Code:
pwm03 = (unsigned char)110;
and the motor starts to "tick"
the light flashes rapidly(faster then when it doesn't have a signal and in sync with the "ticks")
one of our mentors thinks that for one reason or another the signal is pulsing too slowly and is causing the jitter.
i have also determined that sometimes when we change the value too largely it will also "tick"(ex from 127 to 200)
as far as i understand(i could be wrong) the victor takes the PWM and a signal between 1 and 254
i have also tried using unsigned int instead and have gotten the same exact result
i have no clue whats going on(mostly because I'm a rookie) so if anyone could provide info it would be very very helpful
Unread 31-01-2006, 23:47
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Programming Victor 884 control
You don't need the typecasts, simply setting the pwm to a value will work.
Such as:
Code:
pwm03 = 110;
Ticking sounds like not enough power, and 110 is pretty close to the neutral zone. I'd try a lower number, changing speeds rapidly is more of a problem for drivetrains than code. Try using a number like 63, that should be half power reverse, or close to it.
Matt Krass
Unread 01-02-2006, 00:36
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Drake,
The ticking sound you hear is the auto resetting circuit breaker tripping over and over again.
Your problem is mechanical. A chain, (gear, et cetera) is binding in reverse.
You should see the Victor led turn off every time the CB trips in this condition. Hence the synchronous flashing you describe.
Proof: Remove the motor from it's mechanical house of bondage and it will operate just fine with the same code and electronics.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 01-02-2006, 14:42
AKA: Bryant
that would make sence except that the motor isnt attached to anything
i will try not typecasting it when i get my battery recharged
Unread 01-02-2006, 14:45
Jared Russell's Avatar
Taking a year (mostly) off
If it isn't the circuit breaker, it may just be innoculously flip-flopping between two values (one within the deadband and one within the negative motion range) - no big deal. PWM signals are somewhat inexact. See if you get the same results with, say, a value of 100.
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Then it's either a defective speed controller or defective motor.. Try a lower value though. If you want proof, get a decent multimeter (Depending on the motor, it could be drawing 40+amps at 12v) and mesasure the voltage coming off the speed controller.
Unread 01-02-2006, 17:41
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
After you have tried everything else and are sure that the circuit breaker isn't tripping, (It produces a distinctive buzz and gets very warm>) then calibrate the speed contoller. It sounds like you might be on the hairy edge of being in the dead band (127 +/- 10). This is likely true if your joystick or pot input is sitting on the same table as the motor.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-02-2006, 22:04
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
It sounds like you need some good old fashioned debugging, since one part is obviously not working right.
1. Try different values for your pwm output (i.e. hook it up to a joystick input). If it works for different values, try calibrating the victor
2. Try running the victor without a motor attached, if it works the motor is screwy
3. Try a different victor, if it works then the first victor is screwy
4. Try it on a different pwm output, if it works you either have a logic error or a broken RC.
You don't necessarily need to do them in that order, typically start with the easiest one to test. That would be disconnecting the motor.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 01-02-2006, 23:05
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Idaman323 is an unknown quantity at this point
Where are you putting this code? I am trying to figure out why you need this. or where you need this. I am still tryign grasp all of the aspects of the code since I only had about 2 weeks to look at it last year.
Thanks
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 01-02-2006, 23:51
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
110 is probably in the neutral range. You will have to go a bit lower for anything to happen with the motor.
Unread 03-02-2006, 16:57
AKA: Bryant
thanks chris it turned out it was the motor. one of the brushes is loose and whne the motor runs in one direction it looses connection thanks alot
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 12-06-2005 01:51
control system programming archiver 2000 17 23-06-2002 22:14
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
