Go to Post If the pattern holds, it's a bizarro year. - GeeTwo [more]
Unread 01-02-2006, 13:04
ajlapp ajlapp is offline
AKA: Anthony Lapp
Re: pic: Team Rush 27 - Shooter Concept
pictures of the turret have already surfaced.......so yes it spins.
it spins as much as we want it to, though i doubt it would ever travel more than 180 degrees. this turret is for precision movement....it mimicks the camera gimble.
as for wires, i can't say. we've managed to build a turret for the last 5 years....wires have never been a "go," "no go," item.......they will most likely run around the back of the device and be placed inside some slick looking wire loom. leave plenty of slack...and bam!, your wired.
i'll let the electric knobs work on that.
Its seems to be made to turn. You can see a globe motor mounted upside down to the left. I think they were just to lazy to actually make the sprocket and at the moment there is just a solid ring.
not too lazy......
there is no sprocket involved. see either picture already posted. it is a 129 tooth, 12DP, 20 degree PA spur gear.
that is hard to draw! not to mention frivolous. keep in mind the title of the pic..."concept." this implies that you aren't seeing a completed drawing.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
pic: Team Rush 27 - Up and out! ajlapp Robot Showcase 17 08-02-2006 18:39
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
pic: Team RUSH 27 Electrical Box austind27 Extra Discussion 20 02-03-2005 19:41
pic: Team Rush 27 - Full Bot Inventor ajlapp Robot Showcase 7 19-02-2005 14:05
