Go to Post You're not crazy. Eleven is the new seven. - Michael Corsetto [more]
Unread 01-02-2006, 09:22
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
pic: team 842 batter with mount
Faridodin "Fredi" Lajvardi KD7WKD
Unread 01-02-2006, 09:37
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: pic: team 842 batter with mount
That looks like a very robust setup. I'm not sure how the bracket is fastened to the battery. I would warn you about modifying the battery in any way. Two years ago we had bolted the anderson power connector on the battery. It was mounted in a safe manner with the bolts not protruding through the battery and just on the top on the plastic tabs. Unfortunately, the inspectors at our regional did not agree that it was safe and ordered us to remove them. We almost had to replace the batteries before they would let us compete. Just warning ya, make sure you have a backup plan
"FIRST is like bling bling for the brain." - Woodie Flowers
Unread 01-02-2006, 09:42
I wonder if the judges will make you count the weight of the brackets as robot weight? I would if I were a judge. If they don't, I could see battery brackets evolving into 15-pound structures that hold the side rails of the 'bot together. They certainly look more robust than our traditional bungee cord method.
What kind of adhesive did you find that adheres to both metal brackets and the plastic battery case? If the battery goes through large temperature changes in shipping it makes me wonder if you will have trouble with thermally-induced material size changes damaging the battery case.
Unread 01-02-2006, 09:51
REVving up for a new season
FRC #2848 (All-sparks)
They didn't use metal, it is extruded Fiberglas, or at least that is what it says in the photo description.
Greg Needel│www.robogreg.com
Unread 01-02-2006, 11:36
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
I'm not sure how they will rule on your brackets, but this is from the manual:
11. R61 - Modifying the Control System
The control system is provided to allow wireless control of the robots. The Operator Interface, Robot Controller, Speed Controllers, Relay Modules, Radio Modems, Batteries, Battery Charger, AC Adapter, and 9-pin cables may not be tampered with, modified, or adjusted in any way, (tampering includes drilling, cutting, machining, gluing, rewiring, etc.) with the following exceptions:
  • The dip switches on the Operator Interface may be set as appropriate.
  • The user programmable code in the Robot Controller may be customized.
  • The Speed Controllers may be calibrated as described in owner's manuals.
  • The fuse on the Spike relay for the Air Compressor may be replaced with a 20 Amp Snap-Action circuit
    breaker.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 01-02-2006, 17:57
Al Skierkiewicz Al Skierkiewicz is online now
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Freddy,
My first impression is that I see no physical modification to the battery. In fact the fiberglass is an excellent insulator for the battery terminals. However, I would be afraid that students might try to carry or hold the battery by the cover or channel and have it fall on one of them should tyhe adhesive let go. The tough call here is that if the adhesive is strong enough to survive any force, it might just tear out the plastic side of the battery in a collision. It is for just such an event that modification of the battery is not allowed.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-02-2006, 18:00
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Under <R61> this would not seem valid as it appears you have glued or otherwise liquid-fized something to the side of the battery...
You should probably post on FIRST Q&A over the legality of this. I would think that they would want to include the weight of the components on the battery in your robot weight, if no other rules prohibit it from being allowed.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 01-02-2006, 18:13
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
Well I think it wont be allowed because you are modifying the weight of the battery as well and we all know they don't count the weight of the batteries when weighing the robot. Meaning you get an extra weight for the center of gravity and such.
Unread 01-02-2006, 18:17
Please, please, please let's not mix up judges, referees, and inspectors. Judges to not have anything to do with the robot's compliance to the rules of how it is weighed.
Unread 01-02-2006, 18:19
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Sometimes that'll happen to me, I wont know what to call who I'm talking about so I call them a judge, mostly because they are judging the robot and such ^_^
Unread 05-02-2006, 10:57
AKA: Ledge
We have done this before,all the judges want is the same pieces that are attached to the battery to be placed on the robot for weighing purposes. They approved it before, if they don't do it this time, 1 min. later the battery can be made compliant. No Prob
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
