Go to Post i swear, if it were april fools day, i would not believe this whole lord dumpling/dean kamen thing...but then again, this is FIRST - sure_smile [more]
Unread 01-02-2006, 16:38
krADLEY krADLEY is offline
AKA: Kreag Bradley
FRC #1559 (Devil-Tech)
Team Role: Communications
krADLEY will become famous soon enough
pic: Belt drive 1559
http://www.xanga.com/deviltech1559
Please post your comments at our blog. It gets updated every Tues. Thurs. and Sat. night.
Unread 01-02-2006, 16:39
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: pic: Belt drive 1559
looks easy to adjust the tension. nice.
does that belt have teeth on both sides?
Unread 01-02-2006, 16:42
AKA: Kreag Bradley
Yes it does
Unread 01-02-2006, 16:43
AKA: Kreag Bradley
They are small though so that may need to be looked at
Unread 01-02-2006, 17:26
Shooter or lifter?
Unread 01-02-2006, 17:35
AKA: Kreag Bradley
This is the lifter. I'm intending on posting the shooter later in the week.
Unread 01-02-2006, 17:41
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Looks heavy.
Is 25-30 lbs about right??
Unread 01-02-2006, 17:45
AKA: Kreag Bradley
Yea it is rather heavy. We are planning to drill holes throughout the frame to decrease the weight. Even after it may be heavy. The bright side is, the material is extremely strong.
Unread 01-02-2006, 21:37
PARhodes's Avatar
PARhodes PARhodes is offline
FRC #1559 (Devil Tech)
PARhodes has a little shameless behaviour in the past
its not all that heavy. with the motor it comes to 18 lbs. The material, minitek is indestructable. its strength to weight ratio is incredible.
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
What teams have used belt drive on previous robots? Alex Cormier Technical Discussion 10 06-11-2004 09:08
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
