Go to Post One team at the UTC regional scored over 2100 points in autonomous alone. I was highly impressed. - Greg Marra [more]
Unread 04-02-2006, 19:36
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: pic: Toltechs drive-train teaser
Originally Posted by Rick TYler
Maybe eight inches is too high? It's important to remember that Poof balls squish. Here's a thought. A lot of teams are going to do sweepers that have counter-rotating rollers or belts designed to lift balls from the ground. Many of these will be slanted back, or have curved ramps that skim along just above the ground. What if, instead, the lifter was a belt that went up vertically, with a pressure plate about six inches away. The center point of the bottom roller of the conveyor is below the center point of a ball (how about 2-1/2 inches?), and the bottom of the pressure plate is about 5-3/4 inches from the floor. You drive the bottom of the plate over the ball, which, since you are impacting it well above its CG, starts to roll. The robot is moving faster than the ball, so it drives over it. The ball then rolls into the bottom of the conveyor which acts as a wheel, lifting the rear edge of the ball. The ball tries to roll forward, but, since the force from the belt is actually a vector pushing forward AND up, it rises a little. Once it lifts up, it becomes trapped between the belt and the pressure plate, which act just like a single-wheel shooter and a pressure plate or bar, and the ball walks up the pressure plate into a curved sheet, which walks it over into a hopper.
This must have come to me in a dream. I'm sure it's not the design we are using on Top Gun. Incidentally, this is a testimony to prototyping. We would have a sloped ramp with a curved Lexan floor sweeper (which would act just like a bulldozer blade and knocked balls out if we hit them going fast) and two rollers if we hadn't built three prototypes of this. Now we know exactly what geometry will work, and how fast the belt needs to go. Not that this is our design or anything...
This is actually the same exact idea that I had towards the beginning of the season. We are not using it either though...
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
