Re: White Paper Discuss: .NET (2.0) Composite Dashboard Viewer
There is an error in the type library that will cause team numbers to be incorrect. Attached is a patch to correct problem. Thanks to Mike Betts for not only finding the problem, but proposing the correct solution. Unzip the two dll's in the attachment and drop them into the folder with FRCDashboard.exe.
The controls assembly is included because I added a widget to display the robot's heading. Its very simple, looks sort of like a compass. The UpdateHeading() method does exactly what you'd think. |
| White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team | Jessica Boucher | Extra Discussion | 1 | 20-11-2005 20:01 |
| White Paper Discuss: .NET Composite Dashboard Viewer | seanwitte | Extra Discussion | 8 | 06-04-2005 00:15 |
| White Paper Discuss: 2004 Visual Basic 6 Dashboard Control | CD47-Bot | Extra Discussion | 2 | 01-02-2005 01:56 |
| White Paper Discuss: 2004 .NET dashboard control dll | CD47-Bot | Extra Discussion | 7 | 13-01-2005 17:32 |
| White Paper Discuss: Team 810's 2004 Dashboard Backend | CD47-Bot | Extra Discussion | 1 | 07-03-2004 10:32 |
