Re: pic: Dual FP KOP Tranny
This is most likely for a shooter because the output rpms seems very high I would guess arround 1200 or so.
We are using this for our "shooter" (per FIRST definition). RPM is actually around 450 based on 16,000 free speed.
Ken Patton says "Our F-P is a 9012, and it has a 32 pitch, 19 tooth pinion on it" and mine are the same. The mating gear is 46 tooth that I had lying around but is available through PIC (not recommended per bad experience with this company), Berg, Stock Drive and others. I had a 46 tooth, I suggest the readily available 45 tooth for anyone who wants to copy this. The specs on FP motors are scattered throughout CD, a five minute search will give you specs on multiple years. The motors come with different tooth counts, typically 16 or 19. Good Luck! |
| Dual fields | Keith Chester | Rumor Mill | 11 | 05-04-2005 17:57 |
| Looking for KOP Helical Gears | ChuckDickerson | Kit & Additional Hardware | 1 | 21-07-2004 15:39 |
| Team 968's technokat inspired 4 speed tranny | Travis Covington | Robot Showcase | 12 | 01-03-2004 10:06 |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 07-10-2003 15:04 |
