Go to Post It would be interesting to be able to take robots from multiple years and invent new games they can play together (Calvin Ball). - Mark McLeod [more]
Unread 06-02-2006, 11:41
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: pic: Dual FP KOP Tranny
We are using this for our "shooter" (per FIRST definition). RPM is actually around 450 based on 16,000 free speed.
Ken Patton says "Our F-P is a 9012, and it has a 32 pitch, 19 tooth pinion on it" and mine are the same. The mating gear is 46 tooth that I had lying around but is available through PIC (not recommended per bad experience with this company), Berg, Stock Drive and others. I had a 46 tooth, I suggest the readily available 45 tooth for anyone who wants to copy this.
The specs on FP motors are scattered throughout CD, a five minute search will give you specs on multiple years. The motors come with different tooth counts, typically 16 or 19.
Good Luck!
Andy Brockway
Team 716, The Who'sCTEKS
Dual fields Keith Chester Rumor Mill 11 05-04-2005 17:57
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
