Go to Post It's The Hunger Games and those lucky teams are Prim. - Gregor [more]
Unread 06-02-2006, 13:27
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: Toltechs drive-train teaser
Originally Posted by Andrew Rudolph
Looks like you guys are wel on your way to having a drivable holonomic system. Good luck with that!
Just a question, have you guys tried doubling up the omniwheels with an offset so that theres always a roller in contact with the ground?
We found it to work better with 2 offset wheels, basically the problem without the offset is that without it, the wheel isnt really round, so it bounces and doesnt slide quite as well.
Good luck to you guys and i hope to see you in houston!
Have you tried the new plastic omni-wheels from AM? They've made the rollers wider and with a lower profile so you don't see much bounce with these. I've got another set on order in case we need them or as replacements.
work now is focused on autonomous modes and getting the mechanics of the ball harvesting complete and shooting
Thanks,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
