pic: 213 Design
Re: pic: 213 Design
Looks nice--the best one-point robot I've seen yet.
Good luck this season! |
Re: pic: 213 Design
I would love to see how those wheels of yours work.
Re: pic: 213 Design
I want to see how the power gets from the motor to the wheel.
Re: pic: 213 Design
I hate to be "that guy" but doesn't that ramp violate <S03> based on update 6? It also may violate <R04>.
See this thread: http://www.chiefdelphi.com/forums/sh...9&page=1&pp=15 Last edited by Peter Matteson : 08-02-2006 at 08:02. Reason: browser window crashed before I could paste the link. |
Re: pic: 213 Design
seems like its outside of the allowed footprint. you guys may want to rethink this !
Re: pic: 213 Design
You can extend outside of the footprint! The only time that this cannot happen is for mechanism that throw or expel balls at a high rate. As long as the door does not move too fast there shouldn't be a problem as long as it is a low energy devise that does not exceed 3 m/s
Other than that... How do you plan on getting to the goals? Is your robot powerful enough to push robots out of your way? Or is it fast enough to beat them there. From my experience Omni drive isn’t that fast or that powerful but highly maneuverable. I would also suggest adding side panels to the door to ensure that the balls don’t slide off the edge. Great conveyor design! |
Re: pic: 213 Design
I'm pretty sure this robot follows the rules.
1) that fold down ramp isnt launching balls, just letting them roll into the corner goal, so it doesnt count as a launcher that has to stay in the foot print 2) as far as the wedge rule, so long as the ramp is mounted above 8.5inches (the top of the bumper zone) they are not breaking any rules. <R04> states that parts of the robot between 0 and 8.5 inches off the floor must be 10degrees from vertical. Other parts should be designed to avoid wedging, so as long as they dont go using it to push against other robots they will be fine. Sanddrag: this picture shows their prototype drive, you can see the belts they use to drive the wheels. http://www.chiefdelphi.com/forums/pi...&quiet=Verbose To Team 213, my only suggestion (which you may have already thought of) is add something tall to the bottom of that unloading ramp, that stops your ramp from crossing through the opening of the corner goal, so you dont risk interefering with the scoring system. My old team had to do something very similar in 2004 to keep our ball collector from breaking the plane of the alliance station wall. |
Re: pic: 213 Design
Are you going for the ramp, cause if you are, I would drive up your chute and score points for myself as well. lol
Horray for piggy-back bots. |
#10
Re: pic: 213 Design
I've read all of the rules and Q&A's pertaining to this issue, but there are conflicting opinions. ok, so what's the final word. Is this design legal or illegal?
*assuming there are no obvious violations and that the distance between all points of the "ramp" and the ground exceeds 8.5 inches. Last edited by Courtneyb1023 : 08-02-2006 at 11:34. |
#11
Re: pic: 213 Design
The problem is based on answers like the this:
http://forums.usfirst.org/showthread.php?t=424 And this: http://forums.usfirst.org/showthread.php?t=439 Many of us have argued whether or not a ramp is a shooter. It depends on how you define the interaction of gravity in the situation. When you look at question like this: http://forums.usfirst.org/showthread.php?t=327 It gets muddier because the ramp is delivering the final impulse on the ball in a ball ejection system. While in another series of posts based on <R04> is sounds perfectly legal. I know I'm going off a little off the point here but this was a "Devil's Advocate thing". I mentioned it so that team 213 would feel comfortable that they are within the rules and be ready to argue the situation with the proper Q&A in hand if necessary. With all the discussion on this board I think preparation for talking to the inspectors needs to be made for such a device. Such as: http://forums.usfirst.org/showthread.php?t=552 http://forums.usfirst.org/showthread.php?t=547 |
#12
Re: pic: 213 Design
Hopefully this Q&A is still in effect: http://forums.usfirst.org/showthread...hlight=gravity
Although in our case it may turn out to be a moot point, as we may be too close to the weight limit to install a fold-down door. |
#13
Re: pic: 213 Design
Hey, someone else is using Kornylak transwheels...
#14
Re: pic: 213 Design
Re: pic: 213 Design
sweet robot.. how are the omniwheels working for you guys
| pic: My wheel/leg design | mechanicalbrain | Extra Discussion | 17 | 07-10-2005 12:01 |
| pic: my more specific design | mechanicalbrain | Robot Showcase | 6 | 29-06-2005 22:39 |
| Team 862'sEDUbot Design competition | GhostInTheShell | Off-Season Events | 4 | 26-06-2005 18:10 |
| Programming a 2nd PIC | ImmortalAres | Programming | 8 | 16-06-2005 12:13 |
| pic: 1305 Frame design with trannies | CD47-Bot | Robot Showcase | 19 | 25-09-2004 01:13 |
