Re: pic: Team 225 BEAR-O-Metric
We have a optical sensor to detect the ALU Goal Ramp. Automatically opens the door AND prevents driving into the Goal opening. |
Behind us is EXACTLY where we want you. I can't reveal ALL we have up our skirt (anti-pushing algorithm). |
An algorithm wont help if the robot behind you moves at 10 inches per minute and has the gripping power of a belt driven not tread driven robot, hint hint*
*not really |
Beautiful design. I love it. It looks like it would be very effective. Just out of curiosity, how are you getting around rules <S03> and <R04>? It looks as if your drawbridge ramp is outside the starting 28x38 foot print thus violating <S03> and it can let down between 0 and 8.5" from the floor violating <R04>. You might want to double check the discussion in this thread.
From what I understand, assuming that the ramp is just a ramp and isn't propelling it in any way other than gravity, the ramp is within the guidelines of rule <S03>. However, your ramp looks like it is less than 8.5 inches off the ground, and is not within 10 degrees of vertical. Your ramp very well might violate rule <R04>.
Re: (S03) FIRST Q/A answered this issue of a ball release by GRAVITY. (1-26-06) We can not use the conveyor while the door opens - separates the two functions. Re: (R04) Our door rotation is limited so that the front face is not more than 5 degrees from vertical. |
Sounds good! Great design! I would make the sides of the ramp taller to prevent anything pushing you into the goal, even with the algorithm.
#10
Is 5 degrees enough slope to move the balls in quickly enough?...Just a thought. As for being pused in, I would also make the sides of the "ramp" taller so it gives you some kind of protection from going into the goal. Again, just anouther thought. But it appears to be a very solid and simple design with the potential to be a big scorer.
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| How do you organize your team? | NoodleKnight | Team Organization | 18 | 03-11-2005 22:57 |
| Need Help and Suggestions - Creating a TEAM | Freddy Schurr | Team Organization | 7 | 30-03-2005 22:00 |
| What's the best organizational structure for photos? | maikull | Chit-Chat | 2 | 17-03-2005 17:47 |
| Real names, please | Andy Baker | General Forum | 131 | 21-07-2004 22:07 |
