Go to Post Building a robot to survive 2 districts, a Regional, a Region Championship, and World Championships (plus 4 - soon to be 5 - off season events) is a challenge in itself. - Jared Russell [more]
Unread 10-02-2006, 08:35
Jimmy Holmes Jimmy Holmes is offline
It's not all about the robots
FRC #0027 (Team Rush)
Rookie Year: 1997
Jimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of light
Re: pic: Team 27 Electrical Box
You are right, we will look at that red power cable....it could be shorter.
The weight is around 13 lbs. We know that sounds heavy but we have incorporated the battery holding system within the electrical box. Which means we didn't have to build it anywhere else.
The back rail of the box also serves as the rearmost cross-member of the drive train frame. The electrical box actually sits low between the frame rails to help with CG. With the battery,switch and breaker so close to one another no other #6 wire is required. We just have to run the sensor cables and power wires throughout the robot which should not be very much more. All of the power wires are pretty short runs.
It is a tight squeeze in some places but doable. We will try to keep everything neat and labeled.
All of the speed controls are mounted on polycarb. We will wrap any wire bundles that could rub against the aluminum with wire loom or something like that. It is a good point and always should be considered when building boxes such as this. You should try to keep the wires from rubbing against any sharp edges.
Every team please read and respond! Info wanted for FIRST family tree development! Elgin Clock General Forum 99 12-01-2012 03:03
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
Free Kittens/Tetra Grabber Mr. Lim Rumor Mill 30 08-04-2005 11:36
**FIRST EMAIL**/First Annual FIRST Robotics Conference, April 16 April 18, 2004 for t miketwalker FIRST E-Mail Blast Archive 6 04-04-2004 18:31
