Go to Post It’s impossible to know who’s life you will change forever. Don’t miss an opportunity. I’m an optimist. Have a great season. This is the year. - Rich Kressly [more]
Unread 13-02-2006, 00:44
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
pic: Team 254 Teaser
2001-2004: Team 100
2006-Present: Team 254
Unread 13-02-2006, 00:45
Re: pic: Team 254 Teaser
Why did you do a little counterbore where the standoffs go? What effect does that have?
Unread 13-02-2006, 00:47
Engineering Mentor
FRC #0254
If I recall how they have done it in the past correctly, the standoffs are a hollow 1/16" wall .750 OD tubing. As such, the counter bore provides a method of centering the standoff around the through bolt.
I don't know, just a guess... The plates do rock though, nice work!
-Travis Covington
Unread 13-02-2006, 00:50
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
Nice Plate Work
Cant Wait to see the whole robot
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 13-02-2006, 00:54
That makes sense, but I would have just taken round bar and drilled through.
Unread 13-02-2006, 01:04
Engineering Mentor
FRC #0254
Yeah, last year we copied the way they have been doing it. I assume they are doing the same thing this year
Using a much wider tube for a standoff decreases the likelyhood that the two plates will parrallelogram while being no heavier than a smaller solid standoff.
-Travis Covington
Unread 13-02-2006, 04:46
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
cool plates, I like them.
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
Unread 13-02-2006, 08:52
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
That also saves you the time you'd otherwise have to spend on drilling through the solid standoffs. It's a small thing, I know. But it adds up. Clever. =)
-Joel
Unread 13-02-2006, 09:08
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
What material are you using for the side plates? I got to pick one up in Atlanta in 2004 and it felt a little lighter than aluminum.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 13-02-2006, 11:55
Cory's Avatar
AKA: Cory McBride
It's just standard 6061 T6
2001-2004: Team 100
Unread 13-02-2006, 12:17
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
i think its representing the 3 bots... 60, 254, + *22*??? showing as it looks like there is 3 sets of parts there but i could be completely wrong /shrug...
still pretty =D
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 13-02-2006, 13:14
Kirk Kirk is offline
FRC #0254
Rookie Year: 1997
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Nice job on the plates Cory.
Kirk
Unread 15-02-2006, 11:51
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
i can't wait to see the completed bot.
-Matt Durstenfeld
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 254 Teaser phrozen solyd Robot Showcase 20 02-02-2005 00:46
