Go to Post ...your stress reliever is a ziptie with the end cut off so you can pull it straight through. It really works! - Storcky [more]
Unread 13-02-2006, 21:57
Bengineer
Re: pic: 1023 Electronics Board
We used an electronics mounting scheme similar to that last year. 1/4" lexan fits beautifully in the 8020 slot, and you don't need to use any fasteners to keep it in place.
However, I will caution... Be sure to tighten/loctite all the anchor screws on the 8020 connections, and any other mounting hardware that is hidden by the electronics board. We found out the hard way during some elimination rounds, when some "hidden" bolts came loose on our drivetrain. Cut out access points and/or limit the amount of bolts that need to be tightened from the bottom side of the electronics.
Looks great overall. I like the use of the smoked lexan.
BEN
pic: 1023 Teaser #1 KTorak Robot Showcase 12 21-02-2006 19:54
pic: 701 Electronics Board Doug G Robot Showcase 19 13-02-2006 19:40
pic: #1156 Under Control [Brazil] - Electrical components board Daniel_H Extra Discussion 6 30-01-2005 19:56
pic: 1382 Brazil Prototype + Electronic Board tribotec_ca88 Extra Discussion 1 29-01-2005 15:54
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
