Attached is the DLL for the old version of the dashboard with the team number fix applied, for those of us with old views that we don't want to reprogram
EDIT: I found an error that is probably common to both dashboards. iCTRL_B is defined as byte 10 in the dashboards, but the specification (and in real life) says it should be byte 9. I have uploaded the doubly corrected file for the older version, but do not have the tools to correct the newer version.
CMUCam not working? Tracks sporadically? Try this instead:
http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
