Go to Post What really matters is what you got out of the FIRST season, and how you can use it to build on what you know. - Adam Richards [more]
Unread 16-02-2006, 15:45
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
Re: pic: Team 384 Presents: Sparky 7
We have a line of balls that fall down in levels. I will post a picture from the front later to give a better example. We used the kit transmission to gear down and then back up because we wanted to use something we already had to power the wheel, so we started playing around with it and ended up using it. It also gives a good way to adjust the tension in the chain.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Pre-Rookie Teams - The How To Keith Chester General Forum 6 17-09-2008 00:28
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
pic: team 384 CD47-Bot Extra Discussion 5 11-03-2003 19:26
TEAM 384 Sneak Peak ggoldman Robot Showcase 4 09-02-2002 07:32
