Go to Post One career isn't really more prestigious than another; not in and of itself. More than anything it depends on what you do with it. - Matt Leese [more]
Unread 20-02-2006, 13:55
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: pic: team 1029 shifter
it's rather simple device.
1. globe motor is activated, which spins ellipse until next limit switch is pressed
2. the ellipse pushed on the bearing which is connected to a slide, which pushes on the shaft on which the gear cluster is.
3.there are two sets of springs on each side (they can't be seen because they are in between the CIMs.)
4. one spring puts pressure on the gear cluster to put it in high speed (as seen above)
5. when the ellipse spins it overcomes the force of that spring. the other spring now contracts (putting pressure) on to the gear cluster until it "catches" and slides in to low gear.
6. the ellipse is able to be horizontal (with respect to the robot; for low speed) and the gear cluster not engaged, but is being pressured to do so.
this system allows for mechanical shifting without fear of jamming anywhere. in the strange highly unlikely situation that something goes wrong, the shifter will default into high speed.
i hope that answers your question.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
pic: team 1029 bjimster1 Robot Showcase 9 20-02-2006 19:07
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
