Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 21-02-2006, 13:21
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
pic: 179's Swampthing 2006!
www.179swampthing.org
Unread 21-02-2006, 13:22
Re: pic: 179's Swampthing 2006!
Brings a whole new meaning to "wiring," doesn't it?
It looks very swampy. Nice job!
Unread 21-02-2006, 13:25
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Very aggressive looking robot you got there. Does team 179 have a group whose purpose is to make sure the robot is intimidating-looking? Also, I've only been in this game for 5 years, but I'm sure this is the first robot I've seen which uses chicken wire! (Thunderchickens beware?)
Pete Kieselbach
Unread 21-02-2006, 13:46
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
its not chicken wire its poultry netting you can also use it on turkeys and ducks
Unread 21-02-2006, 14:36
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Did your programmers use Kevin Watson's code, or did you do an "in-house" solution?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 21-02-2006, 14:57
Swampdude's Avatar
AKA: Dan Quiggle
I believe they started with Kevin's 2 versions (bells and no bells) but I know They made a lot of changes and then apparently had to completely write a new tracking part. It's impressive to to me since we (179) have never successfully used sensor feedback in a robot design, and this thing is covered with sensors. It also is using the gear tooth sensors. They have each system in PID loops and they (the programmers) use big words like "referential integrity" and "differential gain" that make it soften the locking process (which can get violent). But you can push it while it wants to lock on the light and it just keeps re-centering, but you also have the foot to contend with. Charlie (our code mentor) is amazing at this stuff - he was on team 267 Demolition squad years ago, and now were lucky to have him.
Unread 21-02-2006, 16:43
Eldarion's Avatar
Boy does that sound familiar!
For some reason, both last year and this year I had to rewrite the camera communication and tracking routines.
Our two favorite expressions are:
"I just have to tune the PID loop!"
"It's still downloading!"
-- Thomas Paine
-- Anonymous
Unread 01-03-2006, 23:22
Swampdude's Avatar
AKA: Dan Quiggle
Here's some video from our "scrimmage". At the end you see one of the early Autonomous routines, but you can kind of tell in the picture vs. the video the shooter has been changed. It feeds balls real fast now
Last edited by Swampdude : 01-03-2006 at 23:33. Reason: DOH! Wrong path, its fixed...
Unread 01-03-2006, 23:29
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
the link doesnt work (404 error)
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 04-03-2006, 22:25
Noelle Noelle is offline
#0180 (S.P.A.M.)
Noelle is on a distinguished road
Send a message via AIM to Noelle
Did when I opened it Looks great Swampthing, but I wouldn't expect less.
SPAM rules!
Unread 04-03-2006, 22:39
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Wow... nice bot. But it doesn't look like a swampbot from years past... specifically 2004. I was impressed by the shear look of that robot. One of my favorites of all time. Maybe it's not green enough. Still look awesome though. Good job guys and gals.
Unread 29-03-2006, 10:31
Swampmonkey's Avatar
Swampmonkey Swampmonkey is offline
AKA: Zach
None #0179 (Children of the Swamp)
Swampmonkey is a jewel in the roughSwampmonkey is a jewel in the roughSwampmonkey is a jewel in the rough
Send a message via AIM to Swampmonkey
We kinda ran out of time, didn't have the time to take it apart again to paint it
But at Florida Regionals we did add a lot of black plastic netting, so it looks a little bit more distinguished...look for us at Nationals
All about makin' that G T A . . .
Tragedy is when I cut my finger.
Comedy is when you walk into an open sewer and die.
-Mel Brooks
Team 179 | Children of the Swamp
Member since 2002
Unread 29-03-2006, 17:39
ScoutingNerd175's Avatar
ScoutingNerd175 ScoutingNerd175 is offline
Scouting Away
AKA: Caroline Marr
FRC #0175 (Buzz Robotics)
ScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud ofScoutingNerd175 has much to be proud of
Send a message via AIM to ScoutingNerd175
Smile Re: pic: 179's Swampthing 2006!
I'd really like to, I may have to sneak away from our devision to see it, though. If first continues doing the divisions in the same way, our teams won't be in the same division unless 178 comes to the party, they earned a spot but I don't think they're using it. In which case we would definitely be in the same division.
At any rate, looks like an excellent machine.
Buzz 175 Alumna
University of Michigan, Class of 2012
Syracuse University, Class of 2010
Enrico Fermi High School, Class of 2006
Unread 29-03-2006, 23:07
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Nice robot you got there. I've seen some robots that have the particular system just like that that have been doing well. Do well at nationals!
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
pic: Team 237 2006 Elgin Clock Extra Discussion 7 30-01-2006 16:09
pic: Team 228 - 2006 Teaser #1 artdutra04 Extra Discussion 20 26-01-2006 08:32
pic: WildStang 2006 Teaser 1 Dave Flowerday Extra Discussion 31 25-01-2006 01:30
pic: 2006 X-Cats Animation title board Koko Ed Extra Discussion 6 13-01-2006 16:36
pic: A New Challenge in 2006 Noah Melamed Extra Discussion 2 12-01-2006 12:29
