Go to Post 12 is a dozen, 13 a bakers dozen...47 will be a delphi. - Kimmeh [more]
Unread 22-02-2006, 15:42
Mr.T's Avatar
Mr.T Mr.T is offline
Team Leader
FRC #0522 (Robo Wizards)
Mr.T is on a distinguished road
pic: Team 522, McKee HS. and The Robo Wizards
Unread 22-02-2006, 15:44
ajlapp ajlapp is offline
AKA: Anthony Lapp
Re: pic: Team 522, McKee HS. and The Robo Wizards
Each time you ship your robot:
1. You must ship the 12VDC batteries inside their original box or carton packaging
2. You must use the Styrofoam covering with protective caps covering the battery terminals.
3. Secure the boxed batteries inside the “inner battery box” section of the robot crate in an upright
position. The photograph below is a sample of an inner battery box built to comply with regulations.
This is from the FIRST Manual.......I was just curious, as your photo says no battery.
Were we not required to ship a battery? If this is true I wasted 20 good minutes slapping that useless box in my crate with a worn out old battery inside.
Anthony Lapp
FIRST Engineering Mentor
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Unread 22-02-2006, 15:57
http://www2.usfirst.org/2006comp/Upd...7_Feb-8-06.pdf
