Go to Post I love it when there is someone that obviously "gets it". - dlavery [more]
Unread 23-02-2006, 19:41
pic: 696 Gearbox/Transmission
Engineering Mentor
FRC #0254
Re: pic: 696 Gearbox Transmission
Did you use the standoff screws to mount the CIM motor too? Looks good!
-Travis Covington
Unread 23-02-2006, 19:49
Yes. That's one of the things I like about it. 3 of the 4 standoff screws go all the way through to the CIM motors. The other standoff gets a nut on the motor plate side. There is one bolt in one of the CIMs that is just by itself. You can barely see it in the picture. There may be reduncancy in having the standoff that is closest to the left side of the picture, but eh, whatever.
The gearbox could be narrower by about 3/4" but we have a sprocket inside and are running the chain right out of the box, so, that's where the width is coming from.
By using small wheels (~3.375"), we were able to direct drive and save weight and space. And we can still get on the platform.
Unread 23-02-2006, 21:22
Engineering Mentor
FRC #0254
What did you end up doing with the 13tooth gear?
-Travis Covington
Unread 24-02-2006, 00:56
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is online now
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
How's are you guys getting up the ramp?
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 24-02-2006, 01:28
Ah yes, the 13 tooth gear. Most likely only Travis knows what I'm talking about, but I'll go ahead and say here. We ended up boring out the gear to O size (.316) and broaching in a 3/32 keyway to not quite full depth. So the gear is keyed to a .316 portion of the shaft. The very end of the shaft is turned down to 1/4" Since we already made the plates to fit a .875 OD (.375 ID) bearing, we put the 1/4" end of the shaft in a bronze bushing with .375 OD which rides in the .375 ID. For now, it is working, but we have not extensively tested it. We are in the process of finishing machining for the second robot's drivetrain.
The 13 tooth gear is one of a few things that keep me up at night. It is a tiny little sucker made from not the highest quality materials and it has the potential to undergo considerable stress.
The gearbox has many things that are kind of "on the egde" when it comes to design. For example, the primary reduction gear's teeth are about .025 away from the shifting dog which is spinning in an opposite direction at a much different angular velocity. We have standoffs that are very close to gear teeth. Our ground clearance is extremely low near the wheel. Approximately 3/16" There's quite a few things about it that just plain scare me, but we always overbuild everything, and instinct tells me (and the second set will comfirm) that it'll be okay. There's a lot of stuff that is real close, but it has no means and no reason to move. If it clears now, it will always clear. Anyhow, I don't think two speed dog shifting transmissions come too much smaller or lighter than this.
There is about a 3:1 difference between high and low. And the overall reduction is a bit more than an AndyMark shifter (allowing us to direct drive the wheel).
For getting up the ramp, you'll quickly notice that our wheels do not look capable. But design has speculated and testing has confirmed that indeed they are. Here's the reason why. If you look square on at the face of the wheel, you will not see a good portion of the bottom of the gearbox. In the side view of the robot, the lower portion of the gearbox is completely encapsulated by the wheel. In climbing the ramp at a roughly straight approach, there is no surface that can come into contact with the gearbox because it is in contact with the slighty larger wheel.
Unread 24-02-2006, 03:23
Engineering Mentor
FRC #0254
None of those things sound scary to me at all. I wouldn't worry about any of it. It looks like you have yourselves a nice robot yet again!
-Travis Covington
Unread 24-02-2006, 10:01
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
What is the Pitch Diameter of the 13 tooth gear?
We pressed on 11 tooth 20DP Browning gears onto our CIMS.
We did not use a keyway, we just cut four slots onto their hubs and threw some shaft collars on.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 05-03-2006, 20:36
Originally we had a 20 pitch 13 tooth gear that was supposed to be cut into a shaft so the gear and the shaft would be one. But, due to time constraints, we decided to press it on a 3/8" shaft. Well, that didn't go too well. The "wall" thickness between bore and root diameter was small and we cracked gears trying to press them on.
So, as it currently stands, the gear is on a 5/16" shaft with a 3/32 key and has the potential to be under 15 N-M of torque if somehow something jams up, and the motors stall, and the electrical system is briefly able to provide full current while the motors are stalled. I highly doubt that will ever happen, and I think we'll be alright, but the thought of a big shock load (like going from full forward to full reverse very rapidly) still scares me.
Unread 05-03-2006, 21:03
TriggsJr TriggsJr is offline
US FIRST made me an Engineer
None #0173
TriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to all
Send a message via AIM to TriggsJr
This looks sweet.....Nice Machining job
pic: Concept Gearbox Bill_Hancoc Extra Discussion 12 17-11-2005 20:54
pic: Team 716 Gearbox Andy Brockway Extra Discussion 12 01-02-2005 09:18
pic: Gerrish Gearbox MK-III CD47-Bot Extra Discussion 22 04-09-2003 16:32
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
pic: Gerrish Gearbox MKII CD47-Bot Extra Discussion 63 03-07-2003 00:06
