Re: pic: Fisher price on steriods???????????
A bit scary (all those plastic gears) but nonetheless very interesting and quite useful in the right application.
You know what scares me more than the idea of actually managing to shove two FP motors into the same plastic gear box is that they're wired together. Infact it looks like if you drive one the other will cause it to send a reverse current back to the other, causing it to lock up. But i'm sure you know what you're doing. I'll be at your pits in hartford to demistify this conundrum
They are nylon, and most of the motors you get in the kit of parts that have worms or GB's on them have nylon in them
We did that on our 2004 robot for our ball collector and it worked fine through three regionals, nationals, and three offseason events
This gearbox is going to have a lot of output power, as the two FP motors together are a little less than one-half horsepower, which is about the same as a CIM motor. (2 FP x 170 watts = 340 watts.) From this side picture, it looks like you have the auxiliary FP motor geared into the first stage from between the plastic ribs under the third stage. (The blue part is the original FP motor, and the red is the auxiliary FP motor.) Am I correct in this assumption? ![]() |
| Cost of Fisher Price Motors? | ChuckDickerson | Motors | 2 | 12-06-2005 13:44 |
| pic: RIP Fisher Price Motor | ZZII 527 | Robot Showcase | 6 | 22-02-2005 15:56 |
| Fisher Price pinnion specs? | atmaturen | Technical Discussion | 1 | 12-01-2005 19:39 |
| New Fisher Price Motor - IMPORTANT | Paul Copioli | Motors | 6 | 08-02-2002 13:35 |
| Last year vs. this year Fisher Price Gear | bmusser | Technical Discussion | 4 | 29-01-2002 13:24 |
