Go to Post The teams that do the right thing for the sake of doing the right thing, and for believing in the message of FIRST deserve to be recognized. - Madison [more]
Unread 26-02-2006, 15:14
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: pic: Fisher price on steriods???????????
You know what scares me more than the idea of actually managing to shove two FP motors into the same plastic gear box is that they're wired together. Infact it looks like if you drive one the other will cause it to send a reverse current back to the other, causing it to lock up. But i'm sure you know what you're doing. I'll be at your pits in hartford to demistify this conundrum
Team Website
Unread 26-02-2006, 15:23
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
They are nylon, and most of the motors you get in the kit of parts that have worms or GB's on them have nylon in them
Hows my searching? Call 1-800-Green-Dots
Unread 26-02-2006, 15:25
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
We did that on our 2004 robot for our ball collector and it worked fine through three regionals, nationals, and three offseason events
-Paul
Unread 26-02-2006, 15:26
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Don't you want the motors to spin opposite each other if they are meshed with the same gear?
Unread 26-02-2006, 19:40
artdutra04's Avatar
VEX Robotics Engineer
Nope. If you have two motors geared to the same gear, then there would be an odd number of gears between the motors - resulting in both motors spinning in the same direction.
You know what scares me more than the idea of actually managing to shove two FP motors into the same plastic gear box is that they're wired together. Infact it looks like if you drive one the other will cause it to send a reverse current back to the other, causing it to lock up. But i'm sure you know what you're doing. I'll be at your pits in hartford to demistify this conundrum ;D
I may not be the person who designed this, but the initial stages of a gearbox carry mostly speed and with little torque. As you increase the number of stages in a gearbox, more and more torque is transferred, and that is why the pitch of the gears decrease. The less teeth you have per inch, the larger the teeth get, and the more torque they can transfer.
This gearbox is going to have a lot of output power, as the two FP motors together are a little less than one-half horsepower, which is about the same as a CIM motor. (2 FP x 170 watts = 340 watts.) From this side picture, it looks like you have the auxiliary FP motor geared into the first stage from between the plastic ribs under the third stage. (The blue part is the original FP motor, and the red is the auxiliary FP motor.) Am I correct in this assumption?
Art Dutra IV
世上无难事,只怕有心人.
I believe they are shorting them on purpose, looks as if they are using them as a brake?
Unread 26-02-2006, 16:13
Specialized's Avatar
Specialized Specialized is offline
Student-Parent Liason/I make stuff
AKA: Chris Riedinger
FRC #0195 (CyberKnights)
Specialized is a jewel in the roughSpecialized is a jewel in the roughSpecialized is a jewel in the rough
Send a message via AIM to Specialized
Yes, when you "short" these motors together, they provide what is called an electrical brake, in which one is essentially a generator for electricity which "powers" the other motor, essentially causing them to turn in opposite (or the same) directions, whichever way you have them wired.
Cost of Fisher Price Motors? ChuckDickerson Motors 2 12-06-2005 13:44
pic: RIP Fisher Price Motor ZZII 527 Robot Showcase 6 22-02-2005 15:56
Fisher Price pinnion specs? atmaturen Technical Discussion 1 12-01-2005 19:39
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
Last year vs. this year Fisher Price Gear bmusser Technical Discussion 4 29-01-2002 13:24
