Go to Post If you don't like physical play build a stronger robot. - Koko Ed [more]
Unread 25-02-2006, 15:28
Robocat1 Robocat1 is offline
Team #379 Head Advisor
AKA: Judy Barber
FRC #0379 (Robocats)
Robocat1 has a spectacular aura aboutRobocat1 has a spectacular aura about
Send a message via AIM to Robocat1
pic: 379's 2006 Robot Cat 7
2007 Buckeye Regional Winner (thanks to 291 & 48)
2006 Detroit Engineering Inspiration Award
2004 Buckeye Chairman's Award
and many more, but the above are my proudest moments!
Unread 25-02-2006, 15:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 379's 2006 Robot Cat 7
I like that you slide the conveyor backing out of the way to release balls from your hopper. That's an elegant solution. Typically, how tall is the robot so as to allow that functionality to work?
--Madison--
...down at the Ozdust!
Unread 25-02-2006, 21:08
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
I was going to ask the same thing, but if that door it is sitting in front of is a standard 7-foot door, then it looks like they're safely under the 5 foot limit.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 26-02-2006, 02:43
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
But with their cage door open, its gotta be above 5 feet, in relation to the door it looks much taller with the cage door open. Please correct me if I am wrong, but with the cage up it looks like they are exceeding spec.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 26-02-2006, 03:53
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
I was actually referring to the cage being up. It looking almost as tall as the door is just a trick of the perspective. If you look at the bottom, it appears that the robot is a foot or two past the floor. You have to take this into mind when comparing things in a photo. This being considered, it is definitely within spec (Plus, i'm sure they've thought of that.)
Unread 26-02-2006, 07:45
GaryVoshol's Avatar
Cogito ergo arbitro
My initial thought was, "Too tall" as well. We can't tell without a measurement, but I'm assuming the base is about 36-38". Just eyeballing, and using my fingers as calipers on the screen, that makes the top of the hopper slightly less than 3 feet off the ground - and the top of the gate about 5'6". Plus or minus 6" - hopefully for the team it is minus.
Unread 26-02-2006, 22:28
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
the base is longer than wide, so it's approximately 38 inches.
Based off of that. The top of the conveyor belt is 60 inches.
They are way above the height limitation. Let's hope it seems this way because of the camera angle.
Unread 26-02-2006, 22:33
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
if each ball is 7", you can use them as a reference to estimate the height. from the looks of things, the bot looks waaay over the limit when the gate is opened.
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 26-02-2006, 22:35
Looks like it is probably right at 5' based on this very poor photoshopping I did.
Unread 26-02-2006, 22:36
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Honestly, I think none of you are giving team 379 the credit they deserve.
Do you really all think that with an ENTIRE TEAM of FIRSTers, NOONE on 379 caught the fact that the robot can never exceed 5' in height and corrected their design/design around that?
Seriously; I'd be very suprised if ANY FIRST team managed to miss that- i am confident this is a matter of perspective and assumption- good luck 379, your Robot looks solid, and as said above, thats a very elegant way to release the balls.
I'm sure you will do well this yes.
-Dillon Compton
team 1394
www.metalmoose.com
Unread 26-02-2006, 22:40
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Strange, my initial thought was "How the heck are they using cat 7 cable on a robot..." But I guess im just geeky like that.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 27-02-2006, 00:27
Spikey's Avatar
Its NOT a Camera
FRC #0293 (SPIKE)
Just offering concern, I think its a really cool idea, and it makes an instant backboard for the HP to throw balls at. I like the idea, the picture just made me worry!
Unread 27-02-2006, 01:38
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I'm not trying to belittle Team 379 with what looks like a strong design but I too think it's too high.
I was an inspector last year and you would be amazed what some teams think is legal or didn't read the manual.
I made a copy of the picture and blew it up on my computer and took some measurements. I made one assumption and if I'm wrong I'll admit it and shut up. I assumed the velcro on the crossbeam is 1" wide.
With the velcro blown up to measure .2 inches on my comp screen I measured the bot at 15.5" tall at the main vertical upright taking into account the setback of the wheels at the floor. 15.5 divided by .2 gives you a bot that is 77.5" tall.
I hope I'm wrong.
Just my $0.02.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 27-02-2006, 15:16
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
For the love of god, isn't there someone from team 379 here who can tell us the truth so we can end this ridiculousness?!?!
Unread 28-02-2006, 23:05
there also appears to be some space bellow the bottommost ball on your picture. and 9 balls x 7" inches is 63 inches. LOL somebody from team 379 please clarify! (what Chriszuma says) Is this some optical illusion?
pic: Team 230 2006 Robot: Talon VII Sam Lipscomb Robot Showcase 14 28-02-2006 12:26
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 237 2006 Robot JohnBoucher Robot Showcase 6 22-02-2006 22:23
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
