Go to Post You can take the man out of FIRST, but you can't take FIRST out of the man. - George1902 [more]
Unread 02-27-2006, 05:23 PM
Bengineer
Re: pic: Wildstang 2006
Originally Posted by Billfred
2005, IIRC, was swerve. 2003 and 2004 were swerve for sure.
Wasn't it 2002 that they had the swerve with drop-down tank track? Seems like with all the high-powered motors in the kit this year, you could pull it off.
On a completely unrelated note, how did y'all get matching balls?
Surprisingly, 111's 2005 robot was not a swerve 'bot. Last year, Wildstang used the same "wider is better" philosophy and had a 4wd w/omni's setup. So, based on the apparently narrow frame spacing, I would guess that they're using a similar drive this year, albeit a 6wd setup (based on the very low ground clearance.)
I really like the dual ball track feeding into a central elevator in the center. This is a system similar to 191's, whose video shows a very capable system. Sadly, I don't see a way to easily human load the robot. Is this, finally, a Wildstang 'bot that CAN'T do everything?!
BEN
Unread 02-27-2006, 05:26 PM
REVving up for a new season
FRC #2848 (All-sparks)
To be honest the first thing i thought of was how did you get so many of 1 color combo poof ball?
Looks really solid. Good job 111!
Greg Needel│www.robogreg.com
Unread 02-27-2006, 05:33 PM
Joel J's Avatar
Joel J Joel J is offline
do you..
Joel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond repute
Man, things are starting to shape up!
Joel Johnson
Division By Zero (229) Alumni, 2003-2007
RAGE (173) Alumni, 1999-2003
Unread 02-27-2006, 06:00 PM
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Obviously, they didn't need that extra week
I'm guessing this thing does it all, even serves refreshments.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 02-27-2006, 06:04 PM
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
If I'm not mistaken, the extra space on the flat top is well suited for just this purpose.
Unread 02-27-2006, 06:08 PM
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Reject False Icons
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Anyone know a good way to clean drool off of a keyboard?
WOAH! I like! Can't wait to see video!
Steal back your future
Unread 02-27-2006, 06:23 PM
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
so now where is that polished part that you posted earlier this year on this thing? or at least what was/is it?
Unread 02-27-2006, 06:29 PM
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
wow. Love the wide design! (Why didn't we think of that...*hunts down DT kids*)
It looks like you've got a pretty incredible hopper capacity, especially for such a solid bot. (no CG problems here!)
Good job, can't wait to see you guys at Nats...or sooner (regionals? we're at new jersey and palmetto)
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 02-27-2006, 06:55 PM
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Wildstang - Awesome job as usual
Those parts don't look like the ones that fell out of the case in the video - you guys were joshing us again weren't you!
Unread 02-27-2006, 07:08 PM
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
AHHHHHHHHHHHH what an awesome robot...... good thing we don't face you till nationals
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 02-27-2006, 07:16 PM
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
Lol that about says it all. Lots of things love about the robot first of all the compact design and ability to do everything. Low center of gravity, turret and I don't even wanna know about the drive I knows it amazing because it's Wildstang. Good luck this year 111 nice job see you at nats.
Once again great robot,
Drew
p.s best design I have seen yet
Team 1251 The TechTigers
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
Unread 02-27-2006, 09:09 PM
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Ok first off, AWESOME BOT........so efficient use of space. I'd expect people from NASA to have a hard time doing this. BRILLIANT. Well after saying that, I think I got it figured out. Ok it seems that you kept to the keep it simple stupid. Well anyways I think you have a (two small cim) 4 wheel drive (two traction (front), two omni (back)) also im betting you have a huge tank tread (powered by a minibike cim, lowered with pneumatics) to plant when shooting, to get up the ramp, and to push robots around with some good push power (directly in middle under electronics). For your ball collector (2 fisher price w/ gearbox), I think you can only pick up two balls at a time, that picture is a little misleading, after they are picked up, they are on a rack that moves them with gravity to the back of the bot where they all meet up. From there, they have an agitator or something to keep the balls from getting jamed. Then, they use a two timing belt w/ pulleys to feed the balls up to the shooter (I'm guessing they used a globe). The shooter is a single wheel with the ifi traction tread. They used a small cim. The turret is turned using the vandor.
Also, I'm amazed that from what I think, they are using almost every motor, I'm guessing there batteries would last a minute with them moving around in a match, but i guess if you do it right, you can pull a good 2 minutes out of it if you very efficient, but I wouldnt put it past them, Look at how little space they used!!
That seems to be everything. I know someone that was on Wildstang a few years ago and she let me in on some past secrets of WildStang. I have no clue if any of its right. Wildstang, I'm sorry if i exposed your robot, but this is just a guess. Good Luck To All
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 02-27-2006, 09:18 PM
mgreenley
The physical embodiment of "awesome". That pretty much sums up my feelings on your robot...I can't wait to see you guys at competition!
Unread 02-27-2006, 09:30 PM
POLISH703's Avatar
POLISH703 POLISH703 is offline
The special mentor on the team.
AKA: Joe
FRC #0703 (Phoenix)
POLISH703 has a spectacular aura aboutPOLISH703 has a spectacular aura about
Send a message via AIM to POLISH703
120 pounds of twisted steel and sex appeal
Nice robot.
Unread 02-27-2006, 09:50 PM
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Judgeing from the bot being on the ramp and everything im taking that the shooter isn't at 5'. Now with this I would have to say 'stang is using swerve, even though they do have a nice turret on the top.
Great looking bot!
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
pic: Team 230 2006 Robot: Talon VII Sam Lipscomb Robot Showcase 14 02-28-2006 12:26 PM
pic: Team 228 - 2006 Teaser #1 artdutra04 Extra Discussion 20 01-26-2006 08:32 AM
pic: WildStang 2006 Teaser 1 Dave Flowerday Extra Discussion 31 01-25-2006 01:30 AM
pic: 2006 X-Cats Animation title board Koko Ed Extra Discussion 6 01-13-2006 04:36 PM
pic: Wildstang 2005 Dave Scheck Robot Showcase 72 02-24-2005 11:05 AM
