Go to Post anything is possible with dedication. - [more]
Unread 28-02-2006, 16:35
Anubuss's Avatar
Anubuss Anubuss is offline
AKA: Brian Dixon
FRC #0085 (B.O.B. (Built On Brains))
Anubuss will become famous soon enoughAnubuss will become famous soon enough
Send a message via Yahoo to Anubuss
Re: pic: 85 BOB
Originally Posted by Alex Cormier
As i see many teams now have found out about that light, light, light lexan stuff. I used that for our robot last year and then the same type but the aluminum stuff for a base and it's the best stuff out there. good luck 85!
Yeah, that stuff is the best. If you get a chance, you should check out our crate at the competitions. We made it using this material and some aluminum. Not only does it make our crate light weight (enough to have use avoid shiping fees during 2005), but found a way for the crate to transform back and from from crate mode to robto cart/table/pit back drop mode. It's pretty cool. I'll try to dig up a current picture of it if you want.
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Can the pic controller send the data to pc? sunnyrx7turbo Control System 2 05-08-2005 13:14
pic: Bob Evoy Group Hug! CD47-Bot Extra Discussion 1 01-04-2003 11:48
