Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 01-03-2006, 01:36
John Wanninger's Avatar
John Wanninger John Wanninger is offline
FRC #1732 (Hilltoppers)
John Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond repute
Re: pic: Team 1732's 2006 robot visits the Humane Society
Thanks Alex. We were 7 lbs over, so the team decided to lose the pneumatics and kept the 2 big and 2 small CIMs to propel the bot through AndyMark shifters, but keep it in low gear (or perhaps try shifting w/ servos). Being new at this, the drivers felt comfortable with this. Although the robot is nearly 5' tall, C.G. is 14" off floor, so ramp climbing works pretty well going up backwards. The Globe powered conveyor loads balls from floor into helix. The center 'turnstile' driven by a F.P. gearmotor moves up to 16 balls upward into the CIM powered shooter, or to the rear for lower goal scoring. The shooter turret (Globe driven) rotates about 160 degrees and can be adjusted by operator via closed loop control. If and when the target is "seen", the camera takes over turret control to (hopefully) lock onto target.
"A hundred times every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving..."
--Albert Einstein
2001: FLL852 |2002: FLL20/FLL21 |2003: FLL23/FLL25 |2004: FLL14/FLL16 |2005: FVC22/FLL124 |2006: FLL3/FLL2986/FVC22/FRC1732 |2007:FLL3/FLL34/FLL56/FRC1732
2008: FLL3/FLL18/FRC1732 |2009: FLL101/FLL8963/FRC1732 ...(etc.!)
Unread 01-03-2006, 21:40
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
it's really interesting how many teams are using helixes this year, and that some are using them to carry balls up, and some (like us) to carry them down. awsome design though. If you've got the weight, you might still be able to put just the pneumatic storage tanks on and run the cylinders at 40 psi. That could get you about 12 shifts or so before the tanks run out, which ought to be enough for one match.
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
Disqualifications archiver 1999 13 23-06-2002 21:53
