Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 01-03-2006, 02:16
Re: pic: How 1251 shipped.
Originally Posted by miketwalker
P.S. Do you really need that compressor? If you're just using the air to run the shifting cylinders, you can scrap it. If you're using the AndyMarks like we are, you can get well over 100 shifts while staying above pressure.
The brand of your transmission has absolutely nothing to do with the number of times you can shift it before your air runs out. Anyhow, what pressure are you shifting at? Last year, we shifted at about 45 PSI and got 12 shifts out of one tank. How can you get well over 100? You must have been shifting at a low pressure. We started at about 100 psi in the tank, took 12 shifts, and ended under just 45. But anyway, 12 shifts is shifting once every 10 seconds. So, if shifting is your only pneumatics, you can probably get by with one tank.
Can the pic controller send the data to pc? sunnyrx7turbo Control System 2 05-08-2005 13:14
Scouting 1251 style sebas2mil Scouting 8 26-03-2005 21:06
pic: 2 Robots shipped.... CD47-Bot Robot Showcase 13 04-03-2003 02:43
