Go to Post Bottom line - keep your passion for FIRST and don't let others spoil your fun! - Sean Schuff [more]
Unread 01-03-2006, 21:20
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: pic: How 1251 shipped.
Hey- Dont worrry, you arent the only team in this situation (we shipped with a robot that would be expected in the middle of week 5, at best...). An excellent way we found to cut weight was to replace our heavier box and extruded aluminum with (i think it was 1/8" wall) inch box aluminum with a 3/8" speedhole ~ every 3/4"(on all 4 faces). We used our drillpress, took an hour to do all the pieces we needed; just look at where you will need to attach and dont speedhole there, because you will need to throughbolt. This brought the weight down to about .1lbs/foot for material that wont be taking a beating (hopper frame, stuff inside your 'bot profile, etc...)- heck, it's even pretty strong- I am about 240-250lbs, and I held a 3 ft length of speedholed box at an angle on the ground and stood on it, so it was supporting all my weight and being levered against my foot, and it took me about 5 mins of continuous pressure to get a relatively slight bend.
Good luck, and remember, if nothing else, defense is always useful!
www.metalmoose.com
Can the pic controller send the data to pc? sunnyrx7turbo Control System 2 05-08-2005 13:14
Scouting 1251 style sebas2mil Scouting 8 26-03-2005 21:06
pic: 2 Robots shipped.... CD47-Bot Robot Showcase 13 04-03-2003 02:43
