Go to Post Once again, my schooling is interfering with my education. - Caleb Fulton [more]
Unread 01-03-2006, 02:19
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Re: pic: How 1251 shipped.
Originally Posted by sanddrag
The brand of your transmission has absolutely nothing to do with the number of times you can shift it before your air runs out. Anyhow, what pressure are you shifting at? Last year, we shifted at about 45 PSI and got 12 shifts out of one tank. How can you get well over 100? You must have been shifting at a low pressure. We started at about 100 psi in the tank, took 12 shifts, and ended under just 45. But anyway, 12 shifts is shifting once every 10 seconds. So, if shifting is your only pneumatics, you can probably get by with one tank.
I mentioned the transmission because we used the AndyMarks which means you just need to use the 1/2" cylinders. If they did custom ones they might need larger which wouldn't work as well. If you check for air leaks and pump the PSI to the amount allowed it should last for a good number of shifts.
Chopsaw? Chopsaw.
Unread 01-03-2006, 12:53
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
There is alot of aluminium support structure you can take out of there and still retain structural integrity. We dropped about 20 lbs just losing extra aluminium bars. Just think minimalisticaly.
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 01-03-2006, 13:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'd second what everyone else is saying. If you're only using pneumatics to shift the trannies, ditch the compressor, and precharge one accumulator before the match. We're getting ~50 shifts off of one accumulator, regulated down to 20 PSI.
Someone suggested taking off the AndyMarks in favor of the kit gearbox. I don't know how much one of their current transmissions weighs, but I'm pretty sure an AndyMark is less than a KOP gearbox.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-03-2006, 14:05
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
The transmissions use a 1in stroke piston, which is larger then the Andy marks use .75in inch stroke I believe. The wheels for Sanddrag's information are uhmw and were very cheap to make thanks to our machining facilities, they were done with a CNC mill and we just bought the stock which ran under $200.
-Drew
Team 1251 The TechTigers
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
Unread 01-03-2006, 14:57
Originally Posted by Cory
We're getting ~50 shifts off of one accumulator, regulated down to 20 PSI....
Might want to check the specs on the pneumatic valves - I think they are rated for a minimum pressure of 30psi? Maybe it was only the big valve but its something to look into.
If the valve only switches half way all the air in your tank will leak out.
Unread 01-03-2006, 14:59
Jay W.'s Avatar
Jay W. Jay W. is offline
College, firefighter, robot builder
AKA: Jayba!
FRC #0845 (Cutting Edge)
Jay W. has a spectacular aura aboutJay W. has a spectacular aura about
Send a message via AIM to Jay W.
What what I can see, you've got the an excellent design, you just need to get it together/skinnier!
When we get to Florida, just look for us and we'll be glad to help. Heck, we'll have plenty of people un-crating our machine, I'll come help ya'll out (maybe if theres a T-shirt involved j/k :-P).
my e-mail is jayw(AT)famview.com, if you think of anything, just shoot me a message.
cya at UCF,
~Jay
EDIT:
Just thought of something, could you ditch the compressor and just refill an air tank(s) in between matches?
Jay Wright
Cutting Edge #845
College Student/Mentor/do whatever guy
Unread 01-03-2006, 15:30
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Maybe you guys could rebuild that structure using 1/16 wall aluminum, it looks thick in the picture.
You guys are a great team and I am sure you will be really competitive shooter or not.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 01-03-2006, 15:59
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Here's some ideas for you:
- Replace the big CIMs with smalls ones - there's a few pounds right there (they have more torque too)
- Ditch the compressor and just pre-fill- thats about 6 pounds
- The big A-frame you've got going looks kind of unnecessary. You could probably make it much smaller.
- It looks like you have way more metal than you need on the hopper.
- Those are some incredibly massive transmission plates and mounts. Drill big holes in them.
- You can use much smaller chains. Ours are about half that size, and we've never had problems with breakage.
- You might have to ditch that machined nameplate on the front. It looks like it weighs about 10 pounds; at least use thinner material.
- It looks like all your square bar is 1/8" walled, and you can definitely get away with 1/16". It's probably a bit late to change that though.
- If you can, machine down the gears in the gearbox. By taking down the hub and putting a few holes in them, you can cut them down from about a pound each to about a third of a pound.
- Fill the air system with helium!!
- Edit: you can run the shooter with only one motor, with a chain to each wheel. We are running ours (same horizontal setup) with a single FP motor on a custom gearbox.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 01-03-2006, 18:32
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
Thanks to everyone who has given us advice so far.
As of right now we are a few pounds under!!(Sigh of relief)
As for the competition we plan to modify our hopper to hold A LOT more balls and we will be keeping the large bike motor in the gearbox so we can remain to be a strong defensive robot.
Thanks again for all the support.
The TechTigers
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 01-03-2006, 21:20
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Hey- Dont worrry, you arent the only team in this situation (we shipped with a robot that would be expected in the middle of week 5, at best...). An excellent way we found to cut weight was to replace our heavier box and extruded aluminum with (i think it was 1/8" wall) inch box aluminum with a 3/8" speedhole ~ every 3/4"(on all 4 faces). We used our drillpress, took an hour to do all the pieces we needed; just look at where you will need to attach and dont speedhole there, because you will need to throughbolt. This brought the weight down to about .1lbs/foot for material that wont be taking a beating (hopper frame, stuff inside your 'bot profile, etc...)- heck, it's even pretty strong- I am about 240-250lbs, and I held a 3 ft length of speedholed box at an angle on the ground and stood on it, so it was supporting all my weight and being levered against my foot, and it took me about 5 mins of continuous pressure to get a relatively slight bend.
Good luck, and remember, if nothing else, defense is always useful!
www.metalmoose.com
Unread 02-03-2006, 17:57
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
Thanks everyone for the support. Just to answer some questions and suggestions.
-The wheels are made out of UHMW and the came out to be about $12.00 each and about 1.5 hours of CNCing each one. Also each one weight just under half pound so taking the middle one out wouldn't make a big difference.
-The shooter can not come back on because of the way it was taken off, when we started "the diet" many welds were cutted and makes it impossible for some pieces to come back on.
-As shown in the picture (plus electronics, and storage tanks) the robot weights 109 lbs so we don't have the need to remove pneumatics. Also we will be using the air for a dump truck design.
-We are planing on putting a dump truck in the back of the robot at UCF and we think of cutting up the current hopper to suit our needs.
-Also the paint job looked great before the diet.
Thanks everyone for the support and we have tons of work for Thursday.
No matter what happens to the robot we learned our lesson and we had fun. That's what matters, we still think we can make this a very competitive robot but we were expecting to have a killer machine as you can see on the other pictures. Sometimes we have to go through rough things to become wiser and well as much as i don't like to cut our bot to pieces it was needed to learn our lesson. We are also proud of this robot because it was all student designed, student machined and student built.
Good Luck to every one.
Dave
Team 1251 The Techtigers
Can the pic controller send the data to pc? sunnyrx7turbo Control System 2 05-08-2005 13:14
Scouting 1251 style sebas2mil Scouting 8 26-03-2005 21:06
pic: 2 Robots shipped.... CD47-Bot Robot Showcase 13 04-03-2003 02:43
