Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 02-03-2006, 20:48
GB330033 GB330033 is offline
Programming Manager
FRC #1255 (Team Blarglefish)
GB330033 will become famous soon enough
Send a message via AIM to GB330033
Re: pic: 1255 BlargleBot
Well, if any of you were at LSR last year, you might remember our bot. We were the one running around out there without any sort of manipulator, just playing defense. We wanted to build on that strategy this year, but have some scoring capability. The top can hold 10 balls, and moves up slowly so that the balls roll towards (hopefully into) the corner goal in autonomous. The "wings" as we like to call them come down and herd the balls, we then have some landscape edging on the front end which helps us push the balls into the goals. This way, we can score if needed, but we're gonna rely on our defensive capabilities the most. Also, ramping is no problem.
I'm not really sure how I should take the "cute" comment...
Hook'Em
Unread 02-03-2006, 20:52
bhweezer's Avatar
bhweezer bhweezer is offline
Brandon Higgs
FRC #0364 (Team Fusion)
bhweezer is a jewel in the roughbhweezer is a jewel in the roughbhweezer is a jewel in the rough
Send a message via AIM to bhweezer
You guys definitely caused us some trouble last year at Lone Star in the semifinals. Any time we would go to score a tetra you guys would show up! I hope the defensive strategy works out for you like it did last year and I can't wait to see yall again in Houston.
Team Fusion (364)
Synergy in Motion
Unread 02-03-2006, 21:52
Programming Manager
Yall gave us a bit of a problem too. Stupid ramps...
Also, as a note, we did a "push test" between the 05 bot and BlargleBot...
05 didn't even budge BlargleBot, but BlargleBot pushed 05 with ease. Unfortunately, I was driving 05 via tether, and happened to be sitting right behind it. 05 rammed into me, and then I moved a bit. Therefore, from first hand experience, I can safely say that BlargleBot has a significant amount of power.
Can't wait till LSR!
Hook'Em
Unread 02-03-2006, 23:08
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Can we get some drivetrain specs? I'm just curious, is all...
www.metalmoose.com
Unread 02-03-2006, 23:39
Programming Manager
Simple 4WD w/ kit trannies. 8" wheels, chain driven.Like I said in the picture description, nothing too fancy. We have some tires ordered from McMaster on there right now, but we also ordered traction wheels from IFI, and might swap them out. Once again, nothing too fancy, but it'll get the job done.
Hook'Em
pic: 1018 - Pic 5 - TWINS ? ... (or mirrors ?) Stu Bloom Robot Showcase 7 18-02-2006 15:17
pic: 1018 - Pic 4 - Welded Chassis Stu Bloom Robot Showcase 17 03-02-2006 21:36
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
