Re: pic: Team 254 2006 Robot 1
Awesome bot guys.
Why exactly are you not using the FP motors? 1072's drive is using 2 cims and 2 fps, and the drive we made team 100 is using 4 cims and 2 fp's, all with great success. Me and team 1072 are bringing up the tools to replace pinions, if you need anything done at SVR, just come on over and we'll be glad to help you guys out with this. |
Also, I would say that the hopper by itself can easily hold 20-25 balls, along with having ~5-8 balls in the conveyor system in a match situation. |
1)we were drilling over the robot, and in our haste to get on the field, didn't blow the chips out of the bot. FP proceeds to catch fire. 2) We were replacing said FP, and in our haste to get back out on the field, we connected the FP leads into the conveyor. The driver had control over the conveyor, and the operator had control over the FP's, which were opposing the CIM, and got completely toasted. 3) The screws holding the FP to the AM planetary backed out, and the motor actually fell out of the gearbox. Turns out that while pulling FP motors off of spare AM planetaries, we swapped the mounting plate hardware accidentally, and ended up with screws that weren't loc-tited. After that we took them both off the robot. By removing them we freed up weight that will hopefully allow us to keep our rear roller, add on the camera, and some other miscellaneous hardware. Last edited by Cory : 06-03-2006 at 23:43. |
Just for the record... adding motors normally does not increase pushing ability, just range of top speed. |
If you meant to say it increases pushing ability at higher speeds, you'd be correct, but it definitely does not increase the top speed of the robot. |
More motors does mean more torque, but if you aren't reaching stall torque to begin with, what is the point of adding more torque? It doesn't improve anything in said situation. |
#10
While they didn't mention it, I can't see how they wouldn't. With a high gear of 15 fps and a COF of probably 1.1 or 1.2, and a stall current of over 100 amps, it would be next to impossible to not trip a breaker. Perhaps if you never encountered an obstacle. But as soon as you came up against another robot. Low gear will help, but it still may be possibel to trip it. I don't know. I could runt he numbers but I have no immediate desire to because more is merrier when it comes to motors.
#13
Amazing machine, guys...makes me want to come out of retirement
Good luck this season, and I'll be at SVR to see this monster in person. |
| pic: Team 230 2006 Robot: Talon VII | Sam Lipscomb | Robot Showcase | 14 | 28-02-2006 12:26 |
| How do you organize your team? | NoodleKnight | Team Organization | 18 | 03-11-2005 22:57 |
| First Year Team Assistance - MOEmentum: FYI | Mr MOE | General Forum | 0 | 07-01-2005 14:07 |
| Best Robot Ever(again) | Corey Balint | General Forum | 26 | 04-08-2004 23:03 |
| The 2003 Index of team's post about their robot... | Ken Leung | Robot Showcase | 4 | 28-02-2003 00:18 |
