Go to Post FIRST involves school, parents, family etc etc....at least it does at our house! - MrForbes [more]
Unread 06-03-2006, 23:37
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Team 254 2006 Robot 1
Originally Posted by Veselin Kolev
Awesome bot guys.
Why exactly are you not using the FP motors? 1072's drive is using 2 cims and 2 fps, and the drive we made team 100 is using 4 cims and 2 fp's, all with great success. Me and team 1072 are bringing up the tools to replace pinions, if you need anything done at SVR, just come on over and we'll be glad to help you guys out with this.
we blew 3 FP motors.
1)we were drilling over the robot, and in our haste to get on the field, didn't blow the chips out of the bot. FP proceeds to catch fire.
2) We were replacing said FP, and in our haste to get back out on the field, we connected the FP leads into the conveyor. The driver had control over the conveyor, and the operator had control over the FP's, which were opposing the CIM, and got completely toasted.
3) The screws holding the FP to the AM planetary backed out, and the motor actually fell out of the gearbox. Turns out that while pulling FP motors off of spare AM planetaries, we swapped the mounting plate hardware accidentally, and ended up with screws that weren't loc-tited.
After that we took them both off the robot. By removing them we freed up weight that will hopefully allow us to keep our rear roller, add on the camera, and some other miscellaneous hardware.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-03-2006, 23:46
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Originally Posted by Cory
After that we took them both off the robot. We know we aren't going to win any pushing matches, but we can still play some good defense, due to driver skill. We can make it up the ramp just fine, so really, we don't need them at all. By removing them we freed up weight that will hopefully allow us to keep our rear roller, add on the camera, and re-add the aiming mechanism for the shooter.
Cory, four CI Ms won't ever stall on that robot. The FP's won't determine the winner of a pushing match, the friction applied to the ground via those 6 hot wheels will.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 06-03-2006, 23:49
Yes, but if both bots are able to put the power to the floor (with all these traction wheels floating around, the tables are a little more even), that FP will give you a boost. Not to mention the increased efficieny in acceleration.
Unread 06-03-2006, 23:50
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
I think they're only using two CIMs for drive now.
Unread 06-03-2006, 23:58
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Ah, my mistake. Regardless... I have not seen a CIM stall in FIRST. EVER.
I disagree. If both robots have the same amount of traction, the bot with more ability to turn the wheels will do just that, turn the wheels. A slightly mocked down version of burning out. I believe the lower RPMs help in a situation like that, putting more grip to the floor. Plus the higher load CIM is running more efficiently.
Just for the record... adding motors normally does not increase pushing ability, just range of top speed.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 07-03-2006, 00:11
Cory's Avatar
AKA: Cory McBride
It most certainly does increase pushing ability. More motors means more torque, which as long as you haven't exceeded friction*Normal Force means more pushing ability.
If you meant to say it increases pushing ability at higher speeds, you'd be correct, but it definitely does not increase the top speed of the robot.
2001-2004: Team 100
Unread 07-03-2006, 00:18
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
I really am getting into a bad habit of not thinking things through, sorry. I meant it gives the potential for a higher speed. More torque due to more motors leads to the ability to turn a higher gear ratio resulting in a higher output speed.
More motors does mean more torque, but if you aren't reaching stall torque to begin with, what is the point of adding more torque? It doesn't improve anything in said situation.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 07-03-2006, 00:19
It is quite easy to reach the limit of the electrical system, thus tripping breakers. More motors means lower current draw per motor since they are sharing the load.
Unread 07-03-2006, 00:25
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Where was it mentioned that team 254 had breaker problems with the single CIM per side setup? Another thing I have never seen in FIRST although very possible. I remember back to 03 though, those drills would trip 40's regularly
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 07-03-2006, 00:32
While they didn't mention it, I can't see how they wouldn't. With a high gear of 15 fps and a COF of probably 1.1 or 1.2, and a stall current of over 100 amps, it would be next to impossible to not trip a breaker. Perhaps if you never encountered an obstacle. But as soon as you came up against another robot. Low gear will help, but it still may be possibel to trip it. I don't know. I could runt he numbers but I have no immediate desire to because more is merrier when it comes to motors.
Unread 07-03-2006, 00:42
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Sure it would, 15 fps is outrageous for one CIM/ side to handle well. But when we are talking about pushing and low gear, I hold my claims to be true.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 07-03-2006, 02:46
Adrian Santos Adrian Santos is offline
im back?
AKA: formerly phrozensolyd
FRC #0254 (Cheesy Poofs)
Adrian Santos is an unknown quantity at this point
Send a message via AIM to Adrian Santos
Amazing machine, guys...makes me want to come out of retirement
Good luck this season, and I'll be at SVR to see this monster in person.
Adrian Santos
University of Southern California
BA Public Relations '09
Team 254 Alumnus
Unread 07-03-2006, 03:10
Timmy: Mama, Mama. I want a blue one!
Mama: No Timmy. You can only have a red one.
pic: Team 230 2006 Robot: Talon VII Sam Lipscomb Robot Showcase 14 28-02-2006 12:26
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
