Go to Post If you don't have a hairtie, use a ziptie instead. It works, it's cute, and way geeky. :p - Katie Reynolds [more]
Unread 07-03-2006, 12:07
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
Re: pic: 229 presents Irrational
Originally Posted by DjAlamose
I see that you have two chambers there on your robot, for HP loading. But my question is what happens if balls enter on the other side from opposing HPs or other robots? Does it clog the conveyor or is there some way to prevent balls from going in that side. I also noticed the 8 wheel drive (?) and from past experience I’m guessing that you robot is very strong drive train wise. It also looks to be very close to the ground, do you have problems with the ramp, or are you ignoring that completely? I have allot of questions about this bot especially after watching that video of it.
Well you’re more than welcome to ask whatever questions you would like and I will answer them. Either in this public forum or PM me.
First off, if opposing HPs throw a ball at our conveyor belt, all that happens is it will run down the front of the conveyor than get sucked up the other side, and out the shooter. In practice we chucked balls at it as hard as we could, and that’s what happened, so if opposing HPs want to give us balls it’s more than okay with us.
As for the drive train, it’s not as strong as previous years; we ditched the shifter in the interest of simplicity and reliability. However it is still four motor, custom gearbox that has a decent top speed and decent pushing power, and it climbs the ramp both forwards and backwards which was the point of the 8 wheel drive (the outer four are raised up a bit, so in normal operation is just rides on the center four).
Any other questions feel free to ask.
Chris C.
Mechanical Designer
Team 229
pic: Team 229 at Battlecry?? Adrienne E. Extra Discussion 5 20-06-2005 09:38
pic: 229 and 1020 CD47-Bot Extra Discussion 7 16-01-2004 01:02
pic: BC4 229 team CD47-Bot Extra Discussion 17 17-06-2003 23:00
pic: The Dream Team 229 CD47-Bot Extra Discussion 1 17-06-2003 16:56
