Go to Post FIRST Robotics Competition could NEVER, EVER, EVER feature aquatic robots. - dlavery [more]
Unread 03-04-2006, 23:00
Re: pic: My weekend project
Originally Posted by mechanicalbrain
Actually after some testing I found I can run everything except the larger motors with one of these. If I combine 12 volt cables I can get the larger motors to run but im very hesitant to do it.
NOTE: I haven't run anything for more than brief moments at a time and im going to add fuses before I do anything else.
If that is a power supply from a computer you will fry it running motors. Its not designed to handle large loads (the CIMs can pull >50A when they first start up) and they are not designed to handle inductive loads either.
If you want to power the robot motors you need something with a big transformer that can supply the amps.
Want to learn PIC Programming? Good deal here! Rombus Chit-Chat 2 10-04-2006 11:43
Ideas for my Gold Award Project Sarah Bowes General Forum 4 24-06-2005 18:25
openFIRST Project Stats Timothy D. Ginn FIRST-related Organizations 4 01-06-2005 15:54
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
