Go to Post Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew... - nighterfighter [more]
Unread 10-04-2006, 23:59
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: paper: PID Control Theory for FRC Programming
Originally Posted by Tom Bottiglieri
Just a note:
The equations given in text state the following:
POUT = KP * KERR
But your code shows the proper integer based math method of performing this expression.
POUT = KERR * KP
It's quite clear why the variables need to assume this order, but I did not find it documented that there IS a difference between the "text book" equation and your example.. (it is more accurate to "round" later in the equation, after your numbers have built up.)
Either way, great paper! I plan to include this in my "required reading" for new programmers on my team.
I'll keep that in mind for the next revision of the paper. Meanwhile if anyone has any comments or suggestions, feel free to post them here, or PM/Email them to me. I hope this paper is of use to everyone and I'm also available to answer specific questions either through CD or the contact information in the paper.
Good luck!
Matt Krass
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
White Paper Discuss: An Introduction to C Programming for First Robotics Applications CD47-Bot Extra Discussion 10 26-11-2004 21:54
White Paper Discuss: Official 2004 Introduction to Programming Guide CD47-Bot Extra Discussion 4 26-01-2004 20:59
control system programming archiver 2000 17 23-06-2002 22:14
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
