#15
Re: pic: Omnitrack Summer Project?
Extrusion requires a difficult setup and expensive tooling; it's only cheap in huge volumes. But what about graphite permanent mould casting? If you can get a local casting shop to sponsor you, it wouldn't take much to make a few hundred links.
Basically, you'd need to mill out the mould into two graphite halves with sprues, vents and risers as necessary (usually CNC—a casting shop will be able to do this easily), and it's just a matter of mounting it to a standard fixture (which opens and closes the halves) before you're ready to pour metal (e.g. 390 aluminum). |
| pic: 1541 - SARTANYAC: Beta Project | bombadier337 | Robot Showcase | 2 | 22-02-2006 19:24 |
| pic: Project X climbing up the side of the ramp | CD47-Bot | Robot Showcase | 2 | 25-02-2004 23:24 |
| SCRRF Robotics Summer Camps | Redhead Jokes | Southern California Regional Robotics Forum | 0 | 24-03-2003 15:06 |
| Preseason project | AdamT | General Forum | 4 | 09-09-2002 00:52 |
| MS Project Build Schedule | joe_balint | Technical Discussion | 1 | 07-01-2002 03:25 |
