#16
Re: pic: Omnitrack Summer Project?
I thought of omnidirectional treads too when trying to think of an interesting drive system and it's nice to see that someone else is persuing the idea.
One problem I thought of though is this: If you have 1 tread on each side of the robot, then each tread will only receive about 25% of the total weight of the robot. When you try to push someone forward, you will only be using two of the treads. Since only 50% of your robot weight is on those treads, then you have a significantly reduced pushing power (less traction than a typical 4 wheel robot), even though you are using treads. Then I remembered "Oh wait, omni treads would be sweet!" and it cancelled out the previous thought. |
| pic: 1541 - SARTANYAC: Beta Project | bombadier337 | Robot Showcase | 2 | 22-02-2006 19:24 |
| pic: Project X climbing up the side of the ramp | CD47-Bot | Robot Showcase | 2 | 25-02-2004 23:24 |
| SCRRF Robotics Summer Camps | Redhead Jokes | Southern California Regional Robotics Forum | 0 | 24-03-2003 15:06 |
| Preseason project | AdamT | General Forum | 4 | 09-09-2002 00:52 |
| MS Project Build Schedule | joe_balint | Technical Discussion | 1 | 07-01-2002 03:25 |
