Go to Post ... Better to treat everything like it's about to explode and be wrong than the other way round. - Bongle [more]
Go Back   Chief Delphi > Other > FIRST Tech Challenge
Unread 04-14-2006, 04:58 PM
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Re: pic: kiwi vex robot
Originally Posted by s_forbes
I like that design! It's so compact and sturdy, good job!
yes this is so much better then my old frame it's very stiff and compact
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 04-15-2006, 02:10 PM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I just got this working this morning. I tried for hours last night to code it with EasyC. Apparently doing the math wasn't so easy with EasyC. I'll figure it out later today. What you see it the video is coded with MPLAB in about 20 minutes.
Vex Kiwi Drive
Unread 04-15-2006, 06:51 PM
billbo911's Avatar
Vex Kiwi Drive
As I mentioned earlier, I was working on getting this coded using EasyC v2.0. Well I finally got it working. The math is the same, the process is a little different, but it works. Oddly, the bot works smoother with the code done in MPLAB than it does with the code from EasyC. Anyway, I'm attaching the .hex, .bds and .ecp files from EasyC in the hopes someone else can use them. They are in a .zip file, so download and do what you will with them.
Unread 04-16-2006, 12:50 AM
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
I noticed that your code uses a lot of custom c blocks to do the math. May I suggest using the "assignment" block, located in program flow in order to cut down on the labor. Perhaps it will work better as well.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 04-16-2006, 02:54 AM
billbo911's Avatar
That's the help I'm looking for! My level of knowledge of EasyC is all based on my following the programming guide that came with 1.1 and my limited knowledge of C. So if I do things the hard way, it's quite literally because I didn't know any better. I will look into "assignment" blocks and see what I can do with them. I sure hope your right about it making the bot run better.
Logically speaking, the code should run the same whether I code it in MPLAB or EasyC. Realistically, I just need to figure out how to do it correctly in EacyC.
Thanks again!!
BTW, do you know if there are any detailed tutorials for EasyC 2.0? I found the programing guide for 1.1 quite helpful, but a little short on covering all options.
Unread 04-16-2006, 09:03 AM
Lifer
Indeed there is a very nice tutorial. Unlike most programs, the help file of easyC has been worked on quite a bit and is an excellent resource for any questions regarding the software. The file explains what every block and more. Whats real nice is if you have a problem with a specific block while you are trying to program with it, simply drag it into the program and hit "help".
Oh, and there are some tutorials in the help file, but I believe the first few are the same as what came with your programming guide.
Unread 04-19-2006, 12:32 AM
billbo911's Avatar
Indeed, the tutorials and help files are fairly well implemented in this application. I found them quite helpful in learning both the basic and more advanced features of EasyC. Granted, having little knowledge (emphasis on LITTLE) of C helps tremendously.
Thanks for the suggestion. I used the tutorials and your suggestion to create the attached program created in EasyC. And, yes, it does function as well as the version created in MPLAB.
EDIT: I just double checked this file. It appears that I didn't save my changes, so, these files are the old version. My BAD!!!! I will correct this as soon as I re-create the files correctly. Please stay tuned.
EDIT2: OK, I've replaced the files with the corrected versions. Sorry to anyone who tried the previous ones. These new files were updated to CD on 4/19/06 at 4:25pm PDST
Unread 04-19-2006, 01:45 PM
jgarbers jgarbers is offline
jgarbers is an unknown quantity at this point
Re: pic: kiwi vex robot (slightly OT)
What you see in the video is coded with MPLAB in about 20 minutes.
If I may ask - are you using the "Student Version" of the C18 compiler with MPLAB? If not, what compiler are you using? I'm trying to figure out what's appropriate to buy above and beyond what comes with the stock Vex Programming Kit... I've already bought the easyC v2 upgrade, but I'd like to be able to just edit source code.
Thanks!
Unread 04-19-2006, 02:48 PM
billbo911's Avatar
Thanks!
Excellent question.
I am one of the more impatient people in this world. I couldn't wait for the programming kit to be released through Radio Shack. So, when I found out that there was a possibility to purchase a prototype programming module directly from IFI , I jumped at it. It came with the cables, circuit board (unhoused) and a C-BOT CD which included MPLAB 7.0, C18 and IFI loader. These are all licensed to me and not part of my FRC teams programs. I have since then upgraded all three applications to the most current versions that work with FRC, and they still work with Vex. This allows me to use my laptop with the team to help them in programming and fiddle around with my Vex system as well.
I added EasyC when I bought the kit on sale, then later purchased the 2.0 upgrade. Now I can program in either environment. Honestly, I really like EasyC, it is amazingly powerful for a module based programming environment and is extremely easy to teach noobs the basics of robot programming. I can quite literally have a complete novice programming a Vex bot to work autonomously in less that ten minutes. On the other hand, MPLAB offers a lot more flexibility and advanced programming ability. I am not versed well enough in C to use MPLAB exclusively, but I have to admit, I can do some things in MPLAB much faster than I can with EasyC.
So, what do I recommend? Definitely keep EasyC. Only add MPLAB/C18/IFI Loader when you have mastered the use of EasyC and started running into limitations that require you to program directly in C. I know others will have different opinions, and listen to what they say as well. I base mine on my experience and knowledge level in programming. Weigh others opinions on their experience and ability as well. That will give you the truest measure of "What you should do".
Unread 04-19-2006, 03:00 PM
Excellent question...
Thanks so much for your amazingly useful reply! Robot folks are good folks, I think.
I suspect it's possible to compile and download "manually-edited" C code using everything that comes with easyC -- it seems to be running an external compiler during its build step -- but I have a little more experimenting to do. I've been coding for over 25 years and the drag-the-block approach seems to get in my way, although my kids seem quite comfortable with it. Maybe they'll just use easyC the way it's intended and I can try messing around under the hood in my "copious free time".... then I'll figure out if I can justify MPLAB (which looks very nice, by the way... the free IDE is quite the "gateway drug" for the rest of the product line).
Using WPILib on a Vex robot koenig3456 Programming 2 05-02-2006 02:56 PM
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 04-10-2004 07:08 AM
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 03-10-2004 07:34 PM
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 03-09-2004 06:27 PM
XCats - robot pic on our website archiver 2001 0 06-24-2002 01:06 AM
