Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Go Back   Chief Delphi > Other > FIRST Tech Challenge
Unread 04-16-2006, 02:54 AM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: kiwi vex robot
Originally Posted by Francis-134
I noticed that your code uses a lot of custom c blocks to do the math. May I suggest using the "assignment" block, located in program flow in order to cut down on the labor. Perhaps it will work better as well.
That's the help I'm looking for! My level of knowledge of EasyC is all based on my following the programming guide that came with 1.1 and my limited knowledge of C. So if I do things the hard way, it's quite literally because I didn't know any better. I will look into "assignment" blocks and see what I can do with them. I sure hope your right about it making the bot run better.
Logically speaking, the code should run the same whether I code it in MPLAB or EasyC. Realistically, I just need to figure out how to do it correctly in EacyC.
Thanks again!!
BTW, do you know if there are any detailed tutorials for EasyC 2.0? I found the programing guide for 1.1 quite helpful, but a little short on covering all options.
Unread 04-16-2006, 09:03 AM
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Indeed there is a very nice tutorial. Unlike most programs, the help file of easyC has been worked on quite a bit and is an excellent resource for any questions regarding the software. The file explains what every block and more. Whats real nice is if you have a problem with a specific block while you are trying to program with it, simply drag it into the program and hit "help".
Oh, and there are some tutorials in the help file, but I believe the first few are the same as what came with your programming guide.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 04-19-2006, 12:32 AM
billbo911's Avatar
Indeed, the tutorials and help files are fairly well implemented in this application. I found them quite helpful in learning both the basic and more advanced features of EasyC. Granted, having little knowledge (emphasis on LITTLE) of C helps tremendously.
Thanks for the suggestion. I used the tutorials and your suggestion to create the attached program created in EasyC. And, yes, it does function as well as the version created in MPLAB.
EDIT: I just double checked this file. It appears that I didn't save my changes, so, these files are the old version. My BAD!!!! I will correct this as soon as I re-create the files correctly. Please stay tuned.
EDIT2: OK, I've replaced the files with the corrected versions. Sorry to anyone who tried the previous ones. These new files were updated to CD on 4/19/06 at 4:25pm PDST
Using WPILib on a Vex robot koenig3456 Programming 2 05-02-2006 02:56 PM
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 04-10-2004 07:08 AM
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 03-10-2004 07:34 PM
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 03-09-2004 06:27 PM
XCats - robot pic on our website archiver 2001 0 06-24-2002 01:06 AM
