Originally Posted by Francis-134
Indeed there is a very nice tutorial. Unlike most programs, the help file of easyC has been worked on quite a bit and is an excellent resource for any questions regarding the software. The file explains what every block and more. Whats real nice is if you have a problem with a specific block while you are trying to program with it, simply drag it into the program and hit "help".
Oh, and there are some tutorials in the help file, but I believe the first few are the same as what came with your programming guide.
Indeed, the tutorials and help files are fairly well implemented in this application. I found them quite helpful in learning both the basic and more advanced features of EasyC. Granted, having little knowledge (emphasis on LITTLE) of C helps tremendously.
I noticed that your code uses a lot of custom c blocks to do the math. May I suggest using the "assignment" block, located in program flow in order to cut down on the labor. Perhaps it will work better as well.
Thanks for the suggestion. I used the tutorials and your suggestion to create the attached program created in EasyC. And, yes, it does function as well as the version created in MPLAB.
EDIT: I just double checked this file. It appears that I didn't save my changes, so, these files are the old version.
My BAD!!!! I will correct this as soon as I re-create the files correctly. Please stay tuned.
EDIT2: OK, I've replaced the files with the corrected versions. Sorry to anyone who tried the previous ones. These new files were updated to CD on 4/19/06 at 4:25pm PDST
