Go to Post What is this, presto change-o rules every week? - Racer26 [more]
Unread 19-04-2006, 22:54
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: pic: Omnitrack Summer Project?
With all honesty, this is cool, but it makes no sense to me.
You should put the wheels in a diamond pattern, so when you're pushing forward, you're at around 75 not 50% efficiency.
But what makes no sense, is why you want treads.
For non-deforming surfaces, frictional force is independent of area. IIRC, Tank treads make sense in that they can "dig in" and create normal force (instead of frictional force) but these AM rollers dont deform, dont dig in, dont really do anything but add weight. since there's only two points where the weight is supported (the aluminum sprockets) this is functionally equivalent to having two omnis on each side of the square.
Also, why are you filing? you have access to a SWEET cnc mill, it'd only require a fraction of the machining you did for your wheels
Tatsu out.
pic: 1541 - SARTANYAC: Beta Project bombadier337 Robot Showcase 2 22-02-2006 19:24
pic: Project X climbing up the side of the ramp CD47-Bot Robot Showcase 2 25-02-2004 23:24
SCRRF Robotics Summer Camps Redhead Jokes Southern California Regional Robotics Forum 0 24-03-2003 15:06
Preseason project AdamT General Forum 4 09-09-2002 00:52
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
